Kernel: 6.10.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=98bd4f25-5b18-4300-8978-e64842768c50 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
wm: kwin_x11 tools: avail: lxlock vt: 2 dm: SDDM Distro: Garuda
Type: Desktop System: ASRock product: Z790 LiveMixer v: N/A
Mobo: ASRock model: Z790 LiveMixer serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 13.02
date: 12/29/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
Info: model: 13th Gen Intel Core i9-13900KF bits: 64 type: MST AMCP
microcode: 0x129
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 818 high: 1100 min/max: 800/5500:5800:4300:4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 1100 4: 800
5: 800 6: 800 7: 800 8: 800 9: 1100 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800
23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800
32: 800 bogomips: 191692
Device-1: NVIDIA AD103 [GeForce RTX 4080] vendor: Gigabyte driver: nvidia
v: 560.31.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2704 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.64x15.43")
s-diag: 804mm (31.65")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: MSI G321CU
built: 2022 res: 3840x2160 dpi: 139 gamma: 1.2
size: 700x390mm (27.56x15.35") diag: 800mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.31.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
memory: 15.62 GiB
API: Vulkan v: 1.3.295 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4080 driver: nvidia v: 560.31.02
device-ID: 10de:2704 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.2-arch1.1 (LLVM
Device-1: Intel Raptor Lake High Definition Audio vendor: ASRock
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:22bb class-ID: 0403
API: ALSA v: k6.10.9-zen1-2-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
Local Storage: total: 19.21 TiB used: 15.3 TiB (79.6%)
ID-1: /dev/nvme0n1 maj-min: 259:7 vendor: Seagate model: BarraCuda Q5
ZP2000CV30001 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SU5SH017
temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: TeamGroup
model: T-FORCE TM8FF1001T size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 126 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: EQFM22.1 temp: 56.9 C scheme: MBR
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: TeamGroup
model: T-FORCE TM8FPZ004T size: 3.64 TiB block-size: physical: 512 B
fw-rev: EIFM51.3 temp: 36.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Seagate model: ST12000NM0127
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: G006 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SanDisk 3.2 Gen1
size: 116.57 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: DL17 scheme: MBR
ID-6: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MQ03UBB200
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400 serial: <filter>
fw-rev: 5438 scheme: MBR
ID-1: / raw-size: 464.76 GiB size: 464.76 GiB (100.00%)
used: 409.2 GiB (88.0%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:3
ID-2: /boot/efi raw-size: 1.03 GiB size: 1.02 GiB (99.80%)
used: 10.4 MiB (1.0%) fs: vfat dev: /dev/nvme1n1p3 maj-min: 259:5
ID-3: /home raw-size: 464.76 GiB size: 464.76 GiB (100.00%)
ID-4: /var/log raw-size: 464.76 GiB size: 464.76 GiB (100.00%)
ID-5: /var/tmp raw-size: 464.76 GiB size: 464.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.86 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 9.0 C mobo: 38.0 C gpu: nvidia temp: 39 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1117 fan-3: 3176 fan-4: 0 fan-5: 926
fan-6: 0 fan-7: 0 gpu: nvidia fan: 0%
Memory: total: 48 GiB available: 46.86 GiB used: 5.22 GiB (11.1%)
Processes: 592 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.72 GiB services: org_kde_powerdevil,
Packages: 2395 pm: pacman pkgs: 2369 libs: 644
tools: gnome-software,octopi,paru pm: flatpak pkgs: 26 Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.32
running-in: lxterminal inxi: 3.3.35
System install date: 2024-07-04
Last full system update: 2024-09-11
Relevant software: snapper NetworkManager dracut(custom) mkinitcpio
Failed units: fancontrol.service
i have an issue updating and get the following error message trying to update UEFI.dbx version 217 > 371.
The error reads Blocked executable in the ESP, ensure grub and shim are up to date: No ESP or BDP found.
Not sure what to do. For ever since steam keeps crashing the computer trying to update the shaders, not sure why.
Thanks
