Good morning, after attempting the recent update after a reboot I get the log-in screen, but once logged in I am getting a black screen with what looks like a low resolution.
I say this because I can see the cursor which is huge and fuzzy and if I hit the f7 button on my keyboard window switcher appears briefly but besides that it’s a black screen.
I’m not sure if this is relevant but I do get this prompt from the update:
:: There are 2 providers available for qt6-multimedia-backend:
:: Repository extra
1) qt6-multimedia-ffmpeg 2) qt6-multimedia-gstreamer
Enter a number (default=1): 1
:: There are 2 providers available for qt6-python-bindings:
:: Repository extra
1) pyside6 2) python-pyqt6
I have tried 1 and 2 for both options but get the same result so I don’t think it’s related but wanted to point it out.
Has anyone else had this experience?
Garuda-inxi:
Kernel: 6.7.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=31ddc345-0928-456b-bf48-5c86e845ba38 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: F2A88XN-WIFI v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F2 date: 12/16/2013
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
Info: model: AMD A10-7850K APU with Radeon R7 Graphics bits: 64 type: MT MCP
arch: Steamroller level: v2 built: 2014 process: GF 28nm family: 0x15 (21)
model-id: 0x30 (48) stepping: 1 microcode: 0x6003103
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 2837 high: 2994 min/max: 1700/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2470 2: 2948
3: 2994 4: 2937 bogomips: 29549
Device-1: AMD Kaveri [Radeon R7 Graphics] driver: radeon v: kernel
alternate: amdgpu arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm
built: 2013-17 ports: active: none empty: DVI-D-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:01.0 chip-ID: 1002:130f class-ID: 0300
Device-2: NVIDIA GM107GL [Quadro K1200] driver: nvidia v: 550.54.14
2024-02; EOL~2026-12-xx) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:13bc class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia,radeon
alternate: fbdev,nv,vesa dri: radeonsi gpu: radeon,nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
s-diag: 600mm (23.62")
Monitor-1: DP-1 pos: primary res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: None-2-1 size-res: N/A modes: N/A
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: Quadro K1200/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.276 layers: 14 device: 0 type: discrete-gpu
name: Quadro K1200 driver: nvidia v: 550.54.14 device-ID: 10de:13bc
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 24.0.2-arch1.1 (LLVM 16.0.6)
Device-1: AMD Kaveri HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:1308 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
Device-4: GEMBIRD Honk HK-5002 USB Speaker
lanes: 1 mode: 1.1 bus-ID: 2-1:2 chip-ID: 1908:2070 class-ID: 0300
API: ALSA v: k6.7.8-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.1.0 status: active with: 1: pipewire-pulse
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:08b1 class-ID: 0280
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3
chip-ID: 045e:02e6 class-ID: 0000 serial: <filter>
Device-4: TP-Link Archer T2U PLUS [RTL8821AU] driver: rtl88XXau type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-2:2 chip-ID: 2357:0120
IF: wlp0s16f0u2 state: up mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-3:2 chip-ID: 8087:07dc
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 1.36 TiB used: 96.4 GiB (6.9%)
model: WD10EZEX-60WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
used: 96.4 GiB (20.7%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 14.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 24.1 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 60 C fan: 42% device: radeon
temp: 25.0 C
Memory: total: 16 GiB note: est. available: 14.57 GiB used: 2.72 GiB (18.6%)
Processes: 231 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.76 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1905 libs: 568 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-20
Last full system update: 2024-03-04
