Hello,
am trying to install garuda linux with dual boot windows and facing issue with installation more precisely after installing it when pc reboots,after it gets installed and gets rebooted,then there's no dual boot option appearing to choose between windows 10 and garuda.windows was first installed.
i have 3 drives,nvme sn570 where my windows is,wd hard drive where some files are stored and wd ssd 120gb where am trying to install garuda,and bootloader is also being installed on this drive.i have created partitions for home,root,boot even 8mb unformatted but unsuccessful,i have tried installing it multiple time and same issue persists as it doesnt provide any option for selecting between windows and bios doesnt have garuda linux option for boot option as if bootloader not being recognized by bios or installing.
tried multiple times with both open sources and drivers,secure boot and fastboot is disabled.
below i have provided garuda-inxi from garuda live,if you know fix pls let me know
╭─garuda@garuda in ~ as 🧙
╰─λ garuda-inxi
misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZED_RAPTOR quiet
systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0
Type: Desktop Mobo: Gigabyte model: B360M GAMING HD
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: F15b
date: 09/16/2020
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
desc: 1x9 MiB
Speed (MHz): avg: 1150 high: 2900 min/max: 800/4100 scaling:
5: 800 6: 2900 bogomips: 34798
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Gigabyte driver: nvidia
v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:2182 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 91 s-size: 535x301mm (21.06x11.85")
s-diag: 614mm (24.17")
Monitor-1: DP-4 pos: primary res: 1920x1080 dpi: 90
size: 544x303mm (21.42x11.93") diag: 623mm (24.52") modes: N/A
Monitor-2: HDMI-0 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX 1660
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
Device-2: NVIDIA TU116 High Definition Audio vendor: Gigabyte
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 1.48 TiB used: 0 KiB (0.0%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 234110WD temp: 33.9 C scheme: GPT
model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
model: WD10PURZ-85U8XY0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Blade
size: 7.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.26 scheme: MBR
ID-1: swap-1 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.0 C pch: 57.0 C mobo: N/A gpu: nvidia
temp: 49 C
Processes: 191 Uptime: 7m wakeups: 0 Memory: 15.55 GiB
used: 3.72 GiB (23.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1223
libs: 322 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date: 2023-09-04
Last full system update: 2023-09-04
