Hello, I'm using Garuda KDE Dragonized on a system with HDDs and SSDs and I want my HDDs shut down after 15minutes of not being used, so they don't make noise anymore. I already tried hdparm and gnome-disks (which was my go-to software for this problem so far), but both didn't work.
I appreciate any help.
╭─leetsch2002@DESKTOP in ~
╰─λ garuda-inxi
Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=6bf2fd60-5bcf-49a1-8f0a-55b3687cb794 rw rootflags=subvol=@
resume=UUID=11eb62e4-36a7-43bd-a30b-df8ffca3446f loglevel=3
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0902
date: 09/08/2017
ID-1: hidpp_battery_0 charge: 79% condition: N/A volts: 4.0 min: N/A
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001129
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1931 high: 3152 min/max: 1550/3800 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2470 2: 3152
3: 1504 4: 1484 5: 1467 6: 1515 7: 2913 8: 2843 9: 1408 10: 1480 11: 1515
12: 1425 bogomips: 91016
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] vendor: Gigabyte
driver: amdgpu v: kernel bus-ID: 24:00.0 chip-ID: 1002:73df class-ID: 0300
Device-2: webcam type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-1.4:4
chip-ID: 1d6c:0103 class-ID: 0102 serial: <filter>
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Screen-1: 0 s-res: 4480x1080 s-dpi: 96 s-size: 1182x285mm (46.5x11.2")
s-diag: 1216mm (47.9")
Monitor-1: DisplayPort-1 res: 2560x1080 dpi: 81
size: 798x334mm (31.4x13.1") diag: 865mm (34.1")
Monitor-2: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: AMD Radeon RX 6700 XT (NAVY_FLOUNDER DRM 3.44.0
5.16.9-zen1-1-zen LLVM 13.0.1)
v: 4.6 Mesa 21.3.6 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 24:00.1 chip-ID: 1002:ab28
v: kernel bus-ID: 26:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: webcam type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-1.4:4
Device-4: Realtek USB2.0 Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3 chip-ID: 0bda:4937
Device-5: SteelSeries ApS SteelSeries Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4.1:3 chip-ID: 1038:12ad
Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 1e:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp30s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 1-10.3:9 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 7.04 TiB used: 6.36 TiB (90.4%)
model: WDS500G3XHC-00SJG0 size: 465.76 GiB block-size: physical: 512 B
rev: 102000WD temp: 50.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 240GB
size: 223.58 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA300
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
model: Expansion Desk size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 0915 scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 84.96 GiB (85.0%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 349.26 GiB size: 349.26 GiB (100.00%)
used: 295.35 GiB (84.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 84.96 GiB (85.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 31.34 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 58.0 C
mem: 58.0 C
Processes: 447 Uptime: 1h 4m wakeups: 13 Memory: 31.35 GiB
used: 6.63 GiB (21.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1955 lib: 503 Shell: fish
Garuda (2.5.4-2):
System install date: 2021-09-23
Last full system update: 2022-02-15
Snapshots: Timeshift
Failed units: shadow.service
