Is there any way I can lock my keyboard?
Hey there!
Is there any way I can lock my keyboard with a shortcut? Until I hit that shortcut again, none of the keys should work(preferably even the touchpad).
I want to use it as a security addition in case I don’t want to keep logging in with my password every time I leave for a few moments.
inxi:
Kernel: 6.7.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c877fe9c-cef9-4c56-9812-62dcfec9364d rw rootflags=subvol=@
v: 5.115.0 wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Garuda
Type: Laptop System: LENOVO product: 21JRS00U00 v: ThinkPad E14 Gen 5
Mobo: LENOVO model: 21JRS00U00 v: ThinkPad serial: <superuser required>
part-nu: LENOVO_MT_21JR_BU_Think_FM_ThinkPad E14 Gen 5
uuid: <superuser required> UEFI: LENOVO v: R2CET32W (1.14)
date: 11/27/2023
ID-1: BAT0 charge: 43.1 Wh (90.9%) condition: 47.4/47.0 Wh (100.9%)
power: 25.6 W volts: 13.1 min: 11.3 model: Sunwoda L22D3PG4 type: Li-poly
serial: <filter> status: charging cycles: 53
Info: model: AMD Ryzen 5 7530U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2014 high: 2442 min/max: 400/4546 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2373 2: 2363 3: 2370
4: 2395 5: 2360 6: 2355 7: 2442 8: 2395 9: 400 10: 400 11: 2007 12: 2309
bogomips: 47908
Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 55.0 C
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b7ba
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.1-arch1.1
renoir LLVM 16.0.6 DRM 3.57 6.7.6-zen1-1-zen) device-ID: 1002:15e7
memory: 1000 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.1-arch1.1
device-ID: 1002:15e7 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.7.6-zen1-1-zen status: kernel-api tools: N/A
vendor: Lenovo RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4853
Report: btmgmt ID: hci0 rfk-id: 9 state: up address: <filter> bt-v: 5.3
Local Storage: total: 476.94 GiB used: 51.93 GiB (10.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDQMQD-512G-1201 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73116101 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
used: 51.9 GiB (21.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 33.4 MiB (13.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
ID-4: /var/log raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
ID-5: /var/tmp raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 61.0 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (rpm): fan-1: 2200 fan-2: 2200
Memory: total: 16 GiB note: est. available: 14.46 GiB used: 7.83 GiB (54.1%)
Processes: 358 Power: uptime: 11h 27m states: freeze,mem,disk
suspend: s2idle wakeups: 7 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 5.77 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1398 libs: 416 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-01-06
Last full system update: 2024-02-27 ↻
In my opinion, a locked keyboard will no longer be able to respond to keystrokes, which is the purpose of a key lock. Right?
Unless you create a program that enables this key combination and locks all other keys.
Your search on the Internet to see if something like this already exists didn’t turn up anything?
I would look for a usb fingerprint scanner and just lock the laptop like normal.
But he should take the USB Stick with him when he leaves the laptop. If one of his children hides it, he will at least be separated from his data for a while.
A short, complicated password would be better.
Take 69()/ , I always use that :smiley:
I did look for that at first, but the current AUR package is broken.
https://aur.archlinux.org/packages/libfprint-2-tod1-goodix
Yeah, I did search for it. Nothing turned up. It would be simpler to just enable the fingerprint scanner, but the AUR package has issues. I decided not to mess around with it in case I break something.
Regarding the first question, I just want a certain set of keys, which, if pressed in unison, the system will accept it.
Hi!
Did you consider a security key like Yubikey for instance. You can lock computer and just remove it and nothing could unlock it until you insert the key back.
A simple version of it cost around $25 on Amazaon.
Like that:
Two existing packages that may or may not work are lk4b and xtrlock (likely, both X11 only though) .
There are many search results for similar functionality, but most are for X11 too.
A different case but the info may be of use: xinput - In a Wayland session, how to automatically disable input devices when the laptop lid is closed? - Unix & Linux Stack Exchange – one would also need a way to unlock the input devices, and that is something that has to happen without using the disabled devices of course.
Probably, plugging in a mouse or keyboard will do as they are different devices that were not disabled. Or maybe recognize the insertion of a USB key with some file on it.
GIven the “threat model” it doesn’t need to be anything really very safe, it’s one case where “security by obscurity” can be good enough.
update: there’s a catch with the method above, writing to inhibited requires root.
If using a simple script to be called again later when unlocking (as opposed to keeping it running) that would be a bad surprise when it prompts for a password.
One may configure sudo to allow the script to run without password though.
Or simply wait for the unlock event in the script. I’d suggest to inotifywait for some device node (a usb key used as unlock key) to appear, then possibly check some file on it (for added “security”), though the device label or uuid may be enough.
example:
#!/bin/bash
inhibit_input_devices() {
  while read -r line; do
    case "$line" in
      N:*) n="${line:8}" ;;
      S:*) s="${line:9}" ;;
       '') grep -Eiq 'keyboard|mouse|track' <<<$n && echo ${1:0} >/sys/$s/inhibited
    esac
  done </proc/bus/input/devices
inhibit_input_devices 1
sleep 5 # wait for event here
inhibit_input_devices 0
needs be run with sudo, and I’d add a trap to ensure unlocking if it fails midway for some reason. maybe later I update. As it is, it does lock my keyboard and mouse and unlock them after 5 seconds, not very useful, but a start.
@bruh1
A while ago we had a forum member here with a very impressionable nick (no not me) who stopped participating here but still has an account. I have that user’s nick as my laptop’s password. Gotta protect my lil bro from my laptop’s grandness… :wink: (that lil snitch will definitely blab to my parents everything he finds… I don’t wanna receive flying slippers at my age)
That’s why Garuda has snapshots :smiley:
I wouldn’t worry about breaking anything as long as you know your snapshots work and you can restore your system, unless it’s something firmware related to the scanner
if you temporarily lock your keyboard, you could still use an on screen keyboard to enter your password to unlock your computer/reactivate your keyboard.
