I was wondering if there is a way to reset installed packages to basic? (I suppose like “Refresh” for Windoze. I have added too many applications, most of which I do not even use (just passing interest that I thought I would try in the future), and would like to reduce that to bare minimum number of applications and go from there again. I would prefer to keep personal data intact if possible, really just to not have to download several 20+ GB games in Steam again, but I can just reinstall a version of Garuda from scratch if needed. I have been using Garuda for over a year without issues until recently.
I have tried several Linux Distributions in the past and they all invevitably end up in a “Dependency Hell” state where all the different applications require so many different dependencies, even different versions of dependencies and compliled with different options, that something or another breaks irreprably. I have tried separate Root and Home partitions so could just update the Root partition, but that caused space issues no matter what. I am very thankful I found Garuda, particularly with the BTRFS and Snapper features. But I still eventually end up in Dependency Hell. There are so many applications with so many dependencies, I spend more time trying to figure out what went wrong than I do just using the system.
For Garuda, in the past months, I have encountered more and more errors while updating, and being offered install options (choose to install this package or this package) but without any clear explanations about why and what are the consequences. I was hoping Garuda was completely hands-off, with no worrying about the next update wrecking the system functionality, but that does not seem to be the case. So I would like to reduce issues to a minimum and just install the bare minimum, so I have less to troubleshoot.
As you see below, I’ve held off on updating for a while because the last one rendered KDE broken, among other things. I actually had to use Snapper to revert to before the update and things are still not that stable. I just want to reset everything to something simple and working.
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=142514e1-03ba-4679-9e53-322b6d546a88 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: Gigabyte model: H87M-D3H v: x.x
UEFI: American Megatrends v: F10 date: 07/16/2014
Info: model: Intel Core i5-4670 bits: 64 type: MCP arch: Haswell gen: core 4
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
desc: 1x6 MiB
Speed (MHz): avg: 3787 high: 3800 min/max: 800/3800 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3751 2: 3800 3: 3800
4: 3800 bogomips: 27137
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm
built: 2013 ports: active: none empty: HDMI-A-1,HDMI-A-2,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0300
Device-2: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: eVga.com.
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: lanes: 16 ports: active: none off: DVI-D-1 empty: DP-1, DP-2,
DP-3, HDMI-A-3 bus-ID: 05:00.0 chip-ID: 10de:1c02 class-ID: 0300
alternate: fbdev,intel,nv,vesa dri: crocus gpu: nvidia,nvidia-nvswitch
s-diag: 610mm (24")
Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled model: Acer G246HL
serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: crocus device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
3GB/PCIe/SSE2 memory: 2.93 GiB
API: Vulkan v: 1.3.279 layers: 12 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 3GB driver: nvidia v: 550.67 device-ID: 10de:1c02
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel HD Graphics
4600 (HSW GT2) driver: mesa intel v: 24.0.3-arch1.2 device-ID: 8086:0412
surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM 17.0.6 256
bits) driver: mesa llvmpipe v: 24.0.3-arch1.2 (LLVM 17.0.6)
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GP106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: lanes: 16 bus-ID: 05:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Info: services: NetworkManager, smbd, systemd-networkd, systemd-timesyncd
Local Storage: total: 1.82 TiB used: 962.43 GiB (51.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MG04ACA200N
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: FJ3A scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 962.43 GiB (51.7%)
used: 962.43 GiB (51.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 31.2 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 40 C
Memory: total: 32 GiB available: 31.2 GiB used: 2.7 GiB (8.6%)
Processes: 232 Power: uptime: 1h 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 2069 libs: 593 tools: octopi,paru,trizen
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-02-26
Last full system update: 2024-03-30
Failed units: anbox-container-manager.service systemd-networkd-wait-online.service
