Is there a way to disable the side buttons on a mouse?
I just posted the below on Vivaldi’s forum and thought I would ask here if there is anyway to disable the side buttons either in Plasma, the OS, or simply in Chrome based browsers. Thanks
I just got a Cherry Storm keyboard and mouse combo that compared to my past Logitech products I’m just loving. The only issue I’m having is the back and forward buttons on the side of the mouse. They are way too sensitive and I honestly have no need for them. There must be away to disable them either from within the browser (I know in Firefox based browsers it’s pretty straightforward to do so) or on the OS level in any OS. I’m currently running both Garuda and Arch both with the Plasma desktop.
CCCP% garuda-inxi
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=605af279-dbac-4f83-98ce-879f2fa44f3d rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
Megatrends LLC. v: FB1 date: 05/22/2024
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2988 min/max: 545/5573 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2988 2: 2988 3: 2988
4: 2988 5: 2988 6: 2988 7: 2988 8: 2988 9: 2988 10: 2988 11: 2988 12: 2988
13: 2988 14: 2988 15: 2988 16: 2988 bogomips: 143719
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 550.xx+ status: current (as of 2024-09;
EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: HDMI-A-2 empty: DP-4,DP-5,DP-6
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
empty: DP-1, DP-2, DP-3, HDMI-A-1, Writeback-1 bus-ID: 16:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 37.0 C
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting,nouveau
alternate: fbdev,nv,vesa dri: nouveau,radeonsi gpu: nouveau,amdgpu
display-ID: 0
Monitor-1: HDMI-A-2 res: 2560x1440 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: amd radeonsi platforms:
device: 0 drv: radeonsi device: 1 drv: nouveau device: 2 drv: swrast gbm:
drv: radeonsi surfaceless: drv: radeonsi wayland: drv: nouveau x11:
drv: nouveau
API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 24.2.7-arch1.1 glx-v: 1.4
direct-render: yes renderer: NV176 device-ID: 10de:2504 memory: 11.69 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 9 device: 0 type: integrated-gpu name: AMD
v: 24.2.7-arch1.1 device-ID: 1002:164e surfaces: xcb,xlib,wayland
device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256 bits)
driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM 18.1.8)
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Device-2: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
driver: snd_emu10k1 v: kernel bus-ID: 0c:00.0 chip-ID: 1102:0008
class-ID: 0401
Device-3: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
speed: 16 GT/s lanes: 16 bus-ID: 16:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-4: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
lanes: 16 bus-ID: 16:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network vendor: AzureWave
port: c000 bus-ID: 0d:00.0 chip-ID: 10ec:c852 class-ID: 0280
IF: wlp13s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: b000 bus-ID: 0e:00.0
IF: enp14s0 state: down mac: <filter>
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:3 chip-ID: 13d3:3586
Local Storage: total: 16.37 TiB used: 13.85 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR313 temp: 30.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR002 temp: 30.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion HDD
size: 14.55 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 1801 scheme: GPT
used: 13.85 GiB (1.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
ID-1: swap-1 type: zram size: 61.76 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.1 C mobo: 27.0 C gpu: amdgpu temp: 38.0 C
Memory: total: 64 GiB note: est. available: 61.77 GiB used: 2.57 GiB (4.2%)
Processes: 364 Power: uptime: 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.69 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1874 libs: 539
tools: octopi,pacseek,paru,pikaur,yay Compilers: clang: 18.1.8 gcc: 14.2.1
Shell: garuda-inxi default: Zsh v: 5.9 running-in: konsole inxi: 3.3.36
System install date:     2024-12-05
Last full system update: 2024-12-05
Give me a few and I’ll post the inxi
Found a cheat. Bound them to Control.
5 posts were merged into an existing topic: Off Topic Chit Chat - (Silliness factor 5)
