They are trying to get a notifier to start up automatically but are not able to figure out where it needs to go. Let me see if i can’t get them to be more specific.
Ah, thanks.
I’m gonna switch to deepin later.
Since I am not a “real” programmer I would not know what to do.
thanks, ![]()
that all clicking around must be possible with a shell script,
do it
now
Reminder:
Deepin wiki or tips and tricks section???
Why does every post have to be twenty characters long lol.
uuuuuuppppsssss, I change it to
10
later.
Thought it was for thread names, thank you
OMG, I have no KDE settings in Deepin, you change to …
kwin
So, here is all fine on standard ![]()
I didn’t switch it it came that way lol ask @librewish
Also how do I move the conky to the left side of the screen?
1234567890
The delivery of the emojis is delayed by covid19. However, they may be available as early as tomorrow.
I just need to know where you have the file saved?
~/.config/conky/conky.conf
alignment = 'top_left',
New problem, new thread ![]()
Really nice search function in deepin, I forget it ![]()
Seems like there are still issues…
@librewish wait with install.
I am going to try an update after adding the linux and linux-lts kernels. Then on to inkscape and an attempt on a wallpaper. Fair warning I suck lol.
edit adjusted the terminal
Timeshift first just in case.
I do not always know exactly what you want to tell me but the pictures are beautiful
Better one backup too many than none at all
Well kernels installed grub updated good to see you still have the added kernels in advanced menu. btrfs snapshots are there
journalctl -p 3 -xb is messy but normal for deepin. It hasn't been maintained really since july,2019. Everything works so far. Going to test linux and linux-lts kernels now.
linux-lts ![]()
I want to play with this setting in kwin systemsettings. It allows translucency in windows when you move them and when they are in the back ground behind another window.
@SGS you know how i like things to match
I have to test the
linux kernel first this release caused some issues.
default
Ultimate
The linux kernel throws boot errors / failures. It boots and appears ok
OK no more testing. Fun now.
the file should be in either
/etc/xdg/autostart
or
~/.config/autostart
do you have benchmark result of tomb raider
from plain arch, endeavour os or manjaro
for the comparison
I can run it on endeavouros. I’ll report back a little later. From what I remember that is a fair bit faster then cleanjaro and manjaro was just to be honest slow.
