Have a nice day.
You know that I am working about using Hyprland with my Nvidia GT610 average 20days.
And it solved. But not with Garuda Hyprland iso.
Actually Hyprland settings include a lot of options/packages.
So need to try without giving up.
Last Sunday I install 1542145. Garuda . This version Dragonize Gaming KDE.
When I login to Hyprland. Screen has vibration. I press Ctrl+Alt+F6 and turn command line.
Then I login in command line and write “Hyprland” and press Enter.
Hyprland is online!
On left on waybar “Settings” icon. It’s name " ML4W Dotfile Settings"
Opening window. Click “System” tab.
And move down with mouse.
Select your resolution from Monitors (I select 1920x1080.conf)
Move down.
Select Enviroments “nvidia.conf”
Now using without problems. I am trying 4-5days.
Some users said “If you newbie please don’t use the O2 of the room.”
You can see “You may need to use resources from many rooms/resources to succeed”.
Thanks for everything.
