Is KDE display scale factor completely broken in Wayland, or is something configured wrong on my system?
I attempted to try Wayland, and everything was too small on my screen. Normally I have my 4k display scaled by 125% in the KDE monitor settings. So I tried adjusting the same setting under Wayland and looking at text makes me feel like I have vaseline smeared on my eyeballs. It’s just horrible looking beyond belief.
Is that it? It doesn’t work? Or is something else wrong? Running at 100% scaling is not feasible, I need reading glasses to see anything.
Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e47b5a22-506c-4573-b60f-520b613f7533 rw rootflags=subvol=@
drm.edid_firmware=DisplayPort-0:/edid/Samsung-EDID-RGB.bin ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: Z690 AERO D v: -CF
Mobo: Gigabyte model: Z690 AERO D serial: <superuser required>
UEFI: American Megatrends LLC. v: F28 date: 12/14/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x11D
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 3666 high: 5329 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 5300 2: 5300 3: 5300
4: 800 5: 5300 6: 800 7: 5300 8: 800 9: 5300 10: 800 11: 5300 12: 5329
13: 5281 14: 800 15: 5300 16: 800 17: 4200 18: 4210 19: 4201 20: 4175
21: 4208 22: 4200 23: 800 24: 4200 bogomips: 164044
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: XFX driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73a5
Device-2: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.1:5
chip-ID: 1532:0e03 class-ID: 0102
Device-3: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.4:8 chip-ID: 534d:2109
Device-4: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.2:6
chip-ID: 07ca:0110 class-ID: 0102 serial: <filter>
Device-5: Elgato Systems GmbH Game Capture HD60 X
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.1:5
chip-ID: 0fd9:0082 class-ID: 0300 serial: <filter>
s-diag: 1165mm (45.88")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Samsung serial: <filter>
built: 2021 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 801mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 16.0.6 DRM 3.56 6.7.0-zen3-1-zen) device-ID: 1002:73a5
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.274 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 23.3.3-arch1.1
device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a00b class-ID: 0300
Device-4: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-5: MacroSilicon USB Video
Device-6: Focusrite-Novation Scarlett 4i4 USB driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:12
chip-ID: 1235:8212 class-ID: 0103 serial: <filter>
Device-7: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
Device-8: Elgato Systems GmbH Game Capture HD60 X
API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-2: Aquantia AQC113C NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Gigabyte driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 port: N/A bus-ID: 08:00.0 chip-ID: 1d6a:14c0 class-ID: 0200
temp: 44.0 C
Device-3: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:25 chip-ID: 8087:0033
Local Storage: total: 9.56 TiB used: 1.48 TiB (15.5%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 52.9 C scheme: GPT
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 48.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Western Digital
fw-rev: 731100WD temp: 54.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Corsair model: Performance Pro
tech: SSD serial: <filter> fw-rev: 1.0 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: SanDisk model: X110 2.5 7MM 256GB
tech: SSD serial: <filter> fw-rev: 412 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: HGST (Hitachi) model: HMS5C4040BLE640
tech: HDD rpm: 5700 serial: <filter> fw-rev: A5D0 scheme: GPT
ID-7: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.44 TiB (78.9%)
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
used: 1.44 TiB (78.9%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.61 GiB used: 529.8 MiB (0.8%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 35.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
mem: 54.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 542
Processes: 563 Uptime: 3h 28m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.62 GiB used: 9.21 GiB (14.7%) Init: systemd v: 255
Packages: pm: pacman pkgs: 2192 libs: 593 tools: octopi,paru,yay pm: rpm
pkgs: 0 Shell: fish v: 3.7.0 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2023-05-03
Last full system update: 2024-01-18 ↻
Wayland is not implemented well in KDE at the moment. It is still rather buggy. Some things work for some people but not others, etc. Allegedly it will be much improved in Plasma 6.
Thanks for the reply. I just wanted to make sure I wasn’t missing something with my configuration, since it seems like a lot of people are already hopping on the Wayland bandwagon.
And hopping off of it just as fast. Wayland is the problem-child of Fedora/Red Hat, and works best in a Fedora/Red Hat GNOME environment.
It’s slowly bleeding its way into KDE, a non-Red Hat UI.
It has been working very well for many years now in Sway. :wink:
Don't mind me.
