Thank you to both of you for your help.
Sorry about the garuda-inxi
@SGS , I prepared it while writing the post and forgot to attach it.
It does not show a partial upgrade status and I guess as it should. Indeed, I did not install a package, I “manually” overwritten files of one.
Kernel: 6.10.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f22a06c1-1697-4e77-a64d-c7c3677134ba rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Mobo: ASUSTeK model: ROG STRIX B650E-E GAMING WIFI v: Rev 1.xx
serial: <filter> part-nu: SKU uuid: 4017f533-7992-7b14-4800-c87f54534e2f
UEFI: American Megatrends v: 3014 date: 07/17/2024
Info: model: AMD Ryzen 9 7900 socket: AM5 bits: 64 type: MT MCP MCM
arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 dies: 2 smt: enabled
cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 5056 high: 5270 min/max: 545/5435 base/boost: 3700/5450
scaling: driver: amd-pstate-epp governor: performance volts: 1.3 V
ext-clock: 100 MHz cores: 1: 4822 2: 5156 3: 5167 4: 5170 5: 5143 6: 5270
7: 5071 8: 5136 9: 5149 10: 4137 11: 5144 12: 5127 13: 5141 14: 5101
15: 5026 16: 5175 17: 5122 18: 5175 19: 5114 20: 4914 21: 5017 22: 4949
23: 5062 24: 5069 bogomips: 177597
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire NITRO+ driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2, HDMI-A-1, HDMI-A-2, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-1 model: Dell AW3418DW serial: <filter> built: 2017
res: 3440x1440 hz: 120 dpi: 109 gamma: 1.2 size: 798x335mm (31.42x13.19")
diag: 865mm (34.1") modes: max: 3440x1440 min: 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
navi31 LLVM 18.1.8 DRM 3.57 6.10.5-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.6-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.6-arch1.1 (LLVM
Device-2: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
Device-3: Logitech G733 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 5-2.1.3:7 chip-ID: 046d:0ab5 class-ID: 0300
Device-4: Razer USA Nommo Chroma driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.3:4
chip-ID: 1532:0517 class-ID: 0102
API: ALSA v: k6.10.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.2 status: n/a (root, process) with:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
lanes: 1 bus-ID: 08:00.0 chip-ID: 14c3:0616 class-ID: 0280
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:7
chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Local Storage: total: 1.82 TiB used: 439.38 GiB (23.6%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620361WD temp: 60.9 C scheme: GPT
SMART: yes health: PASSED on: 7d 10h cycles: 44
read-units: 3,591,785 [1.83 TB] written-units: 6,566,783 [3.36 TB]
ID-1: / raw-size: 750 GiB size: 750 GiB (100.00%) used: 439.35 GiB (58.6%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5
used: 27 MiB (28.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 750 GiB size: 750 GiB (100.00%)
used: 439.35 GiB (58.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /var/log raw-size: 750 GiB size: 750 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 750 GiB size: 750 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 62.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 83.9 C mobo: 54.0 C gpu: amdgpu temp: 69.0 C
mem: 74.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 661
Memory: total: 64 GiB note: est. available: 62.44 GiB used: 13.2 GiB (21.1%)
Processes: 495 Power: uptime: 1h 53m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.96 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1840 libs: 564 tools: octopi,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash
v: 5.2.32 running-in: konsole inxi: 3.3.35
System install date: 2024-08-03
Last full system update: 2024-08-18
Windows dual boot: Yes
So if I understand correctly @LolFlasherNoobX , linux-firmware updates are not as important as the package name sounds?
I do use Linux systems on a daily basis for a few years now so I’ll manage working around configurations files
I’m just not really well versed in “deeper” mechanisms like kernels, firmware, drivers. I’m quite new to the gaming side of Linux, just over a month!
Usually, my interactions are on limited, embedded Linux devices so all we have is vi
But thank you for your kind explanations anyway!
