Hi, i’ve some dns problem on some site (reddit for example) i’ve tried to change dns by garuda assistant but mostly of them just don’t work and the two who’s working work with trouble with some site.
sudo garuda-inxi
Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4060bff0-d5ad-4bab-a9df-7c467cf42c02 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: Dell product: OptiPlex 7010 v: 01 serial: <filter>
Chassis: type: 15 serial: <filter>
Mobo: Dell model: 0WR7PY v: A01 serial: <filter> part-nu: OptiPlex 7010
uuid: 4c4c4544-0051-3810-8057-b2c04f375931 UEFI: Dell v: A14
date: 06/10/2013
Info: model: Intel Core i5-3470 socket: BGA1155 bits: 64 type: MCP
arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15 process: Intel 22nm
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
desc: 1x6 MiB
Speed (MHz): avg: 3239 high: 3533 min/max: 1600/3600 base/boost: 3200/3600
scaling: driver: intel_cpufreq governor: performance volts: 0.0 V
ext-clock: 100 MHz cores: 1: 3533 2: 2798 3: 3292 4: 3335 bogomips: 25540
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: ASUSTeK driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2184
Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DVI-D-1 note: disabled pos: left model: Dell P2214H
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 note: disabled pos: primary,right model: Acer K272HL
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: zink
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1660 driver: nvidia v: 555.58.02
device-ID: 10de:2184 surfaces: xcb,xlib
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.2 status: n/a (root, process) with:
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Local Storage: total: 465.76 GiB used: 25.67 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
family: Barracuda 7200.14 (AF) size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: HP73 temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 74d 14h cycles: 1768
Pre-Fail: reallocated sector: 100 threshold: 36 attribute: Spin_Retry_Count
used: 25.67 GiB (5.5%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
ID-1: swap-1 type: zram size: 7.71 GiB used: 256 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A
Memory: total: 8 GiB available: 7.71 GiB used: 4.03 GiB (52.3%)
Processes: 282 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1928 libs: 577 tools: octopi,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash
v: 5.2.32 running-in: konsole inxi: 3.3.35
System install date: 2024-08-22
Last full system update: 2024-08-23 ↻
I’ve also already try to change resolv.conf myself with google dns and protect it, but nothing work anymore, and most generally if i remove the ipv6 of resolv.conf when it (barely) work it’s stop working.
i can’t ping ipv4 at all and i don’t have ipv4 on ifconfig
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::5c44:4b9a:4bf3:b971 prefixlen 64 scopeid 0x20<link>
inet6 2a01:cb0c:367:1a00:2262:5cc4:eba4:70ce prefixlen 64 scopeid 0x0<global>
ether b8:ca:3a:a5:f8:5c txqueuelen 1000 (Ethernet)
RX packets 83020 bytes 116395786 (111.0 MiB)
RX errors 0 dropped 27 overruns 0 frame 0
TX packets 33033 bytes 3411745 (3.2 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 20 memory 0xf7100000-f7120000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 19 bytes 3723 (3.6 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 19 bytes 3723 (3.6 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0```
