Iptables in conflict
I have installed garuda mokka on my laptop. After this I’ve tried to install the VPN “Private Internet Access” (pia-linux-3.6.2-08398.run) which I downloaded from the offical web site.
However, once I execute the run file I am getting an error saying this:
:: iptables-1:1.8.11-2 y iptables-nft-1:1.8.11-2 están en conflicto.
(: iptables-1:1.8.11-2 and iptables-nft-1:1.8.11-2 are in conflict)
and I am not able to install the VPN.
I really appreciate if somebody can provide a solution for this.
Thanks in advance.
Seems like PIA’s installation is using the iptables package, whereas garuda has iptables-nft installed instead (which is the compatibility layer to work with the newer nftables, whereas iptables is legacy), and you can’t have both. I don’t know enough about how either of these work, but have you checked the Arch Wiki here: Private Internet Access - ArchWiki ?
Perhaps there are alternative packages listed here that would work for you instead of PIA’s installation.
Link? Github?
Please, post the
Use paru for installation.
paru private-internet-access-vpn
1 aur/private-internet-access-vpn 3.4-4 [+87 ~0.02]
    Installs VPN profiles for Private Internet Access Service
:: Packages to install (eg: 1 2 3, 1-3):
Kernel: 6.15.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=576c0cde-d712-40c4-b3ed-ac65bd80843a rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.2 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Laptop System: LENOVO product: 82K2 v: IdeaPad Gaming 3 15ACH6
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ACH6
Mobo: LENOVO model: LNVNB161216 v: SDK0T76466 WIN
serial: <superuser required> part-nu: LENOVO_MT_82K2_BU_idea_FM_IdeaPad
Gaming 3 15ACH6 uuid: <superuser required> UEFI: LENOVO v: H3CN32WW(V2.02)
date: 02/23/2022
ID-1: BAT1 charge: 33.0 Wh (85.3%) condition: 38.7/45.0 Wh (86.0%)
power: 18.2 W volts: 13.0 min: 11.5 model: 0x43 0x65 0x6C 0x78 0x70 0x72
0x74 0x00 0x32 0x30 0x4C 0x32 0x30 0x43 0x33 0x50 type: Li-ion
serial: <filter> status: charging cycles: 201
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA500011
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1556 min/max: 413/4281 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1556 2: 1556 3: 1556
4: 1556 5: 1556 6: 1556 7: 1556 8: 1556 9: 1556 10: 1556 11: 1556 12: 1556
bogomips: 79059
Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: Lenovo
driver: nvidia v: 575.64.03 alternate: nouveau,nvidia_drm
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0302
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 06:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 37.0 C
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 13d3:56ff
class-ID: 0e02
gpu: amdgpu d-rect: 3840x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: J556J02 built: 2023 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 148 gamma: 1.2
size: 344x195mm (13.54x7.68") diag: 397mm (15.6") ratio: 3:2, 16:10 modes:
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: right model: Lenovo 0x9059 built: 2019 res:
mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 142 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11:
drv: radeonsi inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.1.5-arch1.1
renoir ACO DRM 3.63 6.15.5-zen1-1-zen) device-ID: 1002:1638
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 13 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.1.5-arch1.1
device-ID: 1002:1638 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 Ti Laptop GPU driver: nvidia v: 575.64.03
device-ID: 10de:25a0 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.7 256 bits) driver: mesa llvmpipe v: 25.1.5-arch1.1 (LLVM
20.1.7) device-ID: 10005:0000 surfaces: N/A
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.15.5-zen1-1-zen status: kernel-api tools: N/A
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:5
chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 5 state: up address: N/A
Local Storage: total: 1.84 TiB used: 21.25 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:8 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 25.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 model: NXM-1TB 2242 size: 953.87 GiB
tech: SSD serial: <filter> fw-rev: SN11795 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 438.07 GiB size: 438.07 GiB (100.00%)
used: 21.22 GiB (4.8%) fs: btrfs dev: /dev/nvme1n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 260 MiB size: 259.5 MiB (99.80%)
used: 35.9 MiB (13.9%) fs: vfat dev: /dev/nvme1n1p2 maj-min: 259:2
ID-3: /home raw-size: 438.07 GiB size: 438.07 GiB (100.00%)
ID-4: /var/log raw-size: 438.07 GiB size: 438.07 GiB (100.00%)
ID-5: /var/tmp raw-size: 438.07 GiB size: 438.07 GiB (100.00%)
ID-1: swap-1 type: zram size: 27.25 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p5 maj-min: 259:5
System Temperatures: cpu: 47.2 C mobo: 32.0 C gpu: amdgpu temp: 37.0 C
Memory: total: 28 GiB available: 27.25 GiB used: 9.14 GiB (33.5%)
Processes: 431 Power: uptime: 1d 17h 16m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 10.82 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1607 libs: 483 tools: octopi,paru Compilers:
clang: 20.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
Garuda (2.7.3-1):
System install date:     2025-07-09
Last full system update: 2025-07-11 ↻
Thanks for your quick response.
I just executed that line above and selected option 1, and it build a package and installed, however I am not able to see the app installed. Did I miss something?
If I try to execute it again it says it’s already installed:
1 aur/private-internet-access-vpn 3.4-4 [+87 ~0.02] [Instalado]
:: Paquetes para instalar (ej: 1 2 3, 1-3):
I think this installs only the profiles, no VPN software.
Why don’t you just install and use (e.g.) OpenVPN and the configuration file for it that the tool above will have downloaded (or download it again from the web site)?
I am going to give it a try. The wierd thing is that on my desktop computer I have Garuda Dragronized and everything works fine. Otherwise I am going to move to another garuda flavor or distro. Thanks in advance for all your answeres.
