seems minor so no huge rush.
❯ garuda-inxi funstuff
root=UUID=63f3c83e-5747-44de-974f-c89d4101bd95 rw rootflags=subvol=@
resume=UUID=c0d4fb48-27bb-458a-9d32-db4bea9d7420 loglevel=3 ibt=off
Type: Desktop Mobo: MSI model: Z77A-GD55 (MS-7751) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.11
date: 11/20/2013
Info: model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3368 high: 3900 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3900 2: 1672 3: 3900
4: 3900 5: 3900 6: 3900 7: 3900 8: 1872 bogomips: 56002
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:731f class-ID: 0300
Monitor-1: DP-3 mapped: DisplayPort-2 model: Asus VX238 serial: <filter>
built: 2015 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x290mm (20.08x11.42") diag: 587mm (23.1") ratio: 16:9 modes:
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5600 XT (navi10 LLVM
16.0.6 DRM 3.54 6.6.1-zen1-1-zen) device-ID: 1002:731f memory: 5.86 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 5600 XT (RADV NAVI10) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:731f surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
vendor: Micro-Star MSI 7 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-1: Intel 82579V Gigabit Network vendor: Micro-Star MSI driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503 class-ID: 0200
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 2.91 TiB used: 449.93 GiB (15.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SH103S3120G
tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SH103S3120G
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0107 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Kingston model: SA400S37480G
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD20EZRX-00D8PB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: MBR
ID-1: / raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
used: 16.61 GiB (41.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 71.04 GiB size: 71.04 GiB (100.00%)
used: 17.04 GiB (24.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
ID-5: /var/tmp raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.42 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 512 MiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
mem: 40.0 C
Processes: 311 Uptime: 3m wakeups: 0 Memory: total: 24 GiB
available: 23.42 GiB used: 2.84 GiB (12.1%) Init: systemd v: 254
pm: pacman pkgs: 2044 libs: 583 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2023-04-12
Last full system update: 2023-11-08 ↻
Total system updates: 52
--> Updates per week: 1
Uptime: 3 mins
all i’ve done is redo some minor grub theme changes since the newest update to grub-theme-garuda-dr460nized-r3.b40584e-1 earlier today, since this package update always resets my chosen background image and my GRUB_GFXMODE=1920x1080x32 resolution setting.
how i set the grub background is to use dolphin as root to copypasta a replacement image with an identical file name into the theme’s installation folder at /usr/share/grub/themes/garuda-dr460nized.
i also removed GRUB_TOP_LEVEL="/boot/vmlinuz-linux-lts" from etc/default/grub to resume booting the zen kernel as normal.
i made the changes and then used ‘update-grub’ to set them and my only currently known issue is that garuda-inxi is reporting a reset needed even after a system reset and full shutdown/restart.
thanks G-team =-)
Bro
9 November 2023 03:08
2
Do it again once or twice, if that doesn’t work, then try ‘garuda-update’ and/or ‘update remote fix’ in a terminal. Any help?
SGS
9 November 2023 05:03
4
Is the path and name
/usr/share/grub/themes/garuda/background.png
sudo cp your.pic.png /usr/share/grub/themes/garuda/background.png
yeah, i copy/paste a different image with the same name so i don’t have to mess with configs beyond the gfxmode setting.
Hm, the “should reboot” logic is here:
fish❯ bat /bin/garuda-inxi
61 │ generate_system_update() {
62 │ local last_update
63 │ last_update="$(date -r /var/lib/garuda/last_update +%s 2> /dev/null)" || { echo "Unknown/Never"; return; }
64 │ local reboot=""
65 │ if [ "$last_update" -gt "$(date -r /proc +%s)" ]; then
66 │ reboot=" ${c_131}↻${c_off}"
67 │ fi
68 │ echo -e "$(date -d"@$last_update" +%F)${reboot}"
69 │ }
70 │
I’d say the date on /var/lib/garuda/last_update got messed up, but why?
The script appears to retrieve the last update timestamp from a file in /var/lib/garuda/last_update and store it as the last_update variable, then it checks whether the last_update timestamp is greater than the timestamp of /proc (which should represent the current system time). If last_update is greater, it sets the reboot variable to the reboot icon (“↻”).
Check the timestamps in /var/lib/garuda/last_update and /proc directly and see if you can spot any weirdness there.
Is your system time accurate? The time zones are correctly configured?
this file is completely blank and is 0 bytes, i opened it with kate as user and as admin to double-check.
That is normal, it’s just a “placeholder” file to record the date.
fish❯ ll /var/lib/garuda/last_update
.rw-r--r-- 0 root 9 nov 11:00 /var/lib/garuda/last_update
okay cool.
i just checked my inxi again and this issue seems to have repaired itself.
my area had a power grid failure last night while my system was active - twice my machine was hard-reset due to this.
maybe that fixed it? i have no idea.
my garuda-inxi from a few moments ago:
date: 11/20/2013
Speed (MHz): avg: 2847 high: 3836 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1600 2: 3486 3: 3828
4: 1600 5: 3033 6: 1600 7: 3836 8: 3797 bogomips: 56001
unified: no
mac: <filter>
Local Storage: total: 2.91 TiB used: 447.65 GiB (15.0%)
scheme: MBR
used: 14.49 GiB (36.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
used: 16.88 GiB (23.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
mem: 40.0 C
Processes: 310 Uptime: 34m wakeups: 0 Memory: total: 24 GiB
available: 23.42 GiB used: 3.53 GiB (15.1%) Init: systemd v: 254
pm: pacman pkgs: 2043 libs: 583 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
Total system updates: 54
Uptime: 34 mins
Michael_joseph:
power grid failure
Yep I guess that was the cause of the glitch.
Strange that running garuda-update again did not fix it before though, I have no idea.
I should check but maybe there was nothing to update and the file only gets a new timestamp in that case?
power outage fixed the glitch, not caused it.
i updated twice yesterday and noticed the swish sticking around as i was perusing my hardware info in the system stats page of the garuda assistant for the new boot-time thread and then double checked it by running garuda-inxi.
the power outage happened 7 hours ago and was just fixed by linemen within the last hour.
i’m not sure what caused the glitch or what fixed it, but either way i’m gonna scrub and balance my brtfs drives now >.>
system
Closed
11 November 2023 14:00
13
