Invisible mouse Garuda Hyprland
I’m sorry I couldn’t post the guards-info results but it’s pretty impossible to do that and get on the forums on the affected hardware without a mouse.
Everything was working fine initially and I loved it but upon a restart my mouse simply disappeared and everything I have tried to to has not worked.
I looked for specific mouse settings and couldn’t find anything. I put the following line in, “.profile”:
export WLR_NO_HARDWARE_CURSORS=1
I also used similar methods in the hyprland config file and bashrc to no avail.
Any help would be much appreciated as I love the look of this thing but I could really use a mouse.
Thank you!
Edit: Thanks to Kayo!
  Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=84566137-ded0-4694-9de1-579dba866c50 rw rootflags=subvol=@
  Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 3703
    date: 07/27/2021
  Device-1: hidpp_battery_0 model: Logitech PRO X Wireless serial: <filter>
    charge: 61% rechargeable: yes status: discharging
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2614 high: 4666 min/max: 2200/4950 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2681 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2200 7: 4180 8: 2200 9: 2200 10: 2200 11: 2200
    12: 2200 13: 2914 14: 3700 15: 2200 16: 2800 17: 2200 18: 2200 19: 4666
    20: 2873 21: 3064 22: 2200 23: 2874 24: 2200 bogomips: 177263
  Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: eVga.com. driver: nvidia
    (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-2
    empty: DP-1,DP-3,HDMI-A-1 bus-ID: 0a:00.0 chip-ID: 10de:2206
    compositor: Hyprland driver: X: loaded: nvidia unloaded: modesetting,nouveau
    alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: 1
  Monitor-1: DP-2 model: Samsung LC49G95T serial: <filter> built: 2020
    res: 3840x1080 hz: 120 dpi: 82 gamma: 1.2 scale: 1
    size: 1193x336mm (46.97x13.23") diag: 1239mm (48.8") modes: max: 3840x1080
    min: 640x480
  API: Vulkan v: 1.3.269 layers: 8 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3080 driver: nvidia v: 545.29.06
    device-ID: 10de:2206 surfaces: xcb,xlib,wayland device: 1 type: cpu
  Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
    bus-ID: 0a:00.1 chip-ID: 10de:1aef class-ID: 0403
  Device-3: SteelSeries ApS Arctis Nova Pro Wireless
    lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 1038:12e0 class-ID: 0300
  API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:6 chip-ID: 8087:0029
  Local Storage: total: 5.46 TiB used: 33.23 GiB (0.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 34.9 C
    model: WD40NMZW-11GX6S1 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1014 scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 33.23 GiB (1.8%)
    used: 33.23 GiB (1.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 33.0 C mobo: 30.0 C
  Fan Speeds (rpm): cpu: 0
  Processes: 417 Uptime: 40m wakeups: 0 Memory: total: 32 GiB
  available: 31.25 GiB used: 3.31 GiB (10.6%) Init: systemd v: 254
  pm: pacman pkgs: 1328 libs: 436 tools: paru Shell: fish v: 3.6.1
  running-in: foot inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-11-26
  Last full system update: 2023-11-26
If you can get to a terminal/TTY you could run this to get a URL with your garuda-inxi output:
garuda-inxi | nc termbin.com 9999
Please take a look at Nvidia | Hyprland Wiki . You need to add the Direct Rendering Manager (DRM) kernel parameter.
nvidia_drm.modeset=1
(There might be also something else you are missing, but I lack Hyprland experiance :sweat: )
I have no clue but these ring a bell
Mouse cursor disappear · Issue #1520 · hyprwm/Hyprland · GitHub
cursor_disappears_after_opening_a_window - Reddit
linux - Hyprland mouse icon disappears after Application start - Stack Overflow
Is it the same problem, that is, mouse disappears but you can still click blindly?
edit: message was supposed to be @z-prince :man_facepalming:
It seems your issue is solved, but just for the record, I always have an invisible cursor after installing hyprland. I’ve had the most luck adding the line WLR_NO_HARDWARE_CURSORS=1 to /etc/environment
