Kernel: 6.16.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=d7a1a303-2bdd-495e-b886-b4c7920bab42 rw rootflags=subvol=@
quiet loglevel=3
Type: Desktop System: HP product: HP OmniDesk Desktop M02-0xxx v: N/A
Mobo: HP model: 8D32 v: SMVB serial: <superuser required>
part-nu: BE9D5EA#ABE uuid: <superuser required> UEFI: AMI v: F.08
date: 08/12/2025
Info: model: AMD Ryzen 7 8700G w/ Radeon 780M Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA70520A
Speed (MHz): avg: 2404 min/max: 423/5177 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2404 2: 2404 3: 2404
4: 2404 5: 2404 6: 2404 7: 2404 8: 2404 9: 2404 10: 2404 11: 2404 12: 2404
13: 2404 14: 2404 15: 2404 16: 2404 bogomips: 134392
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, Writeback-1
bus-ID: 08:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 29.0 C
Device-2: Logitech Webcam C200 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:3
chip-ID: 046d:0802 class-ID: 0102 serial: <filter>
compositor: kwin_wayland driver: gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: BenQ GW2270 serial: <filter> built: 2016 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.4-arch1.1
phoenix LLVM 20.1.8 DRM 3.64 6.16.10-zen1-1-zen) device-ID: 1002:15bf
memory: 500 MiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.321 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV PHOENIX) driver: mesa radv v: 25.2.4-arch1.1
device-ID: 1002:15bf surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.4-arch1.1 (LLVM
[Rembrandt/Strix] vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:1640
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Logitech Webcam C200 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.16.10-zen1-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL8852BE-VT PCIe 802.11ax Wireless Network
vendor: Hewlett-Packard driver: rtw89_8852bte v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:b520
lanes: 1 port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 0bda:b86a
Local Storage: total: 953.87 GiB used: 141.04 GiB (14.8%)
model: MTFDKBA1T0QGN-1BN1AABHA size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPSQ050 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 126.95 GiB size: 126.95 GiB (100.00%)
used: 8.31 GiB (6.5%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 648 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 462.1 MiB (0.2%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /var/log raw-size: 126.95 GiB size: 126.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 126.95 GiB size: 126.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.72 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.5 C mobo: N/A gpu: amdgpu temp: 30.0 C
Memory: total: 16 GiB note: est. available: 14.72 GiB used: 3.91 GiB (26.6%)
Processes: 410 Power: uptime: 1h 28m states: freeze,mem,disk
suspend, test_resume image: 5.86 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1226 libs: 340 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.1.1 running-in: konsole
inxi: 3.3.39
Garuda (2.11.1-1):
System install date: 2025-10-06
Garuda release: 251002
Last full system update: 2025-10-06
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard
23/24 checks run in 0.79 seconds ⌛
Powered by garuda-health 🦅
--- CRITICAL ---
- Kernels in /boot are invalid (do not match expected files) (fix available)
Hello,
I have an invalid kernel problem, which is similar to pocman2’s.
The difference is that I didn’t apply the fix! Actually, I applied it yesterday, and it did indeed block me. I decided to reinstall, especially since I wanted a different flavor!
So, this morning I proceeded with the installation, which went as follows:
1- Disabling Secure Boot and deleting the keys.
2- Launching Ventoy and selecting Garuda grub normal.
3- Installation and reboot, then system update.
4- Configuring Secure Boot following Pyrotiger’s guide.
5-Reboot and enable Secure Boot.
6-Startup without problems and sbctl result.
sbctl status
Installed: âś“ sbctl is installed
Owner GUID: ccbc09cc-4db8-4b60-a058-ac59640b5045
Setup Mode: âś“ Disabled
Secure Boot: âś“ Enabled
Vendor Keys: microsoft builtin-db builtin-db builtin-KE
However, when I performed an update, I received this response, which is in find garuda-inxi.
Reading the replies to Pacmon2, I noticed that the command: grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=“Garuda”
contained quotation marks around Garuda! Is this important?
Because in Pyrotiger’s tutorial, there aren’t any. Is that the cause of the problem? If so, is it enough to retype the command mentioned above to get everything back in order?
Thank you for your help!!
