and search in forum about “black screen”
Just a heads up if you use third-party repo in kodi 19 you will most likely have to rebuild the extension. Most of the ones I used are build with a older version of python and @TNE post a tool that I will help your process.
If you're on a laptop with Optimus-manager you'll want to reinstall with Pacman -Syyu. If you reboot before hand you'll get the black screen and have to manually connect to wifi (damn near impossible) or use ether net cable (what I ended up doing).
OT.
Just a heads up, third party sketchy Kodi extensions is one of the most likely attack vectors for infecting a Linux machine with malware.
What virus?
You got that one!
hey, i reinstalled aur packages (with yay) and after built myself from git but Gkraken and other still don't work, what to do?
If you have reinstalled or used 'garuda-update' in terminal, and it still doesn't work, then you have to track down the maintainers of the package, usually a git page, and open an issue with them. Site the python 3.10 links, etc. and your output from terminal running the app or any info you can give them....then wait.
welp, someone else already posted it... the dev is already working on it
When I try and run garuda-update or update it just says error: target not found: garuda-update anyone know why?
pacman -Qi garuda-update
If empty than
sudo pacman -Syu garuda-update
Thank you for the help! Somehow chaotic aur disappeared when I readded it everything seemed to work.
I ran pacman -Syu and garuda-update. However mpv aborts with the following error:
mpv: error while loading shared libraries: libpython3.9.so.1.0: cannot open shared object file: No such file or directory
My mpv is provided by the package "mpv-full", version 0.34.0-1
Am I missing a step?
Edit:
The error occurs, when mpv is run after updates are finished. Not during the update process.
I fixed this by downloading the latest python39 package and telling pacman to install it: sudo pacman -U python-3.9.9-1-x86_64.pkg.tar.zst
The 3.10 version is used by default, but some applications (az, for instance) still require 3.9 dependencies, which will now be present.
Aaaaaaah don't do this! Every other package will behave this way then. Seems like we didn't catch mpv-full while rebuilding
(or is this a compatibility package?)
I don't know where to find the info of it being an compatibility package. Here is the information pacman provides:
╭─malertach@Kepler in ~ took 8s
╰─λ pacman -Qi mpv
Version : 0.34.0-1
Beschreibung : A free, open source, and cross-platform media player (with all possible libs)
Architektur : x86_64
URL : https://mpv.io/
Lizenzen : GPL
Gruppen : Nichts
Stellt bereit : mpv
Hängt ab von : cmocka ffmpeg lcms2 libcdio-paranoia libgl libxss libxinerama libxv
libxkbcommon libva wayland libcaca desktop-file-utils hicolor-icon-theme
xdg-utils lua52 mujs libdvdnav libxrandr jack rubberband uchardet
libarchive zlib vapoursynth openal vulkan-icd-loader shaderc libplacebo
zimg spirv-cross libsixel
Optionale Abhängigkeiten : youtube-dl: for video-sharing websites playback
nvidia-utils: for hardware accelerated video decoding with CUDA [Installiert]
Benötigt von : olivia
Optional für : Nichts
In Konflikt mit : mpv
Ersetzt : Nichts
Installationsgröße : 5,25 MiB
Packer : UFSCar HPC Builder <hpc.ufscar@chaotic.cx>
Erstellt am : Di 02 Nov 2021 14:03:12 CET
Installiert am : Di 14 Dez 2021 20:49:10 CET
Installationsgrund : Ausdrücklich installiert
Installations-Skript : Nein
Verifiziert durch : Signatur
Yup, this needs a rebuild. I was actually on it right now, it does seem like a source can't be downloaded due to the server which its downloading from being offline (https://waf.io). It will automatically be built once its working again though, so it should show up once the people fixed their website
As @guybrush pointed out, az is also affected.
I'm not familiar with this binary, but it seems to be provided by the package "azure-cli".
Maybe pactree -rus python helps in finding affected packages.
Is Whoogle still affected by this? I've added the below if it helps. I have already posted on their github and AUR pages.
╭─locutus@Borg in ~
╰─λ pacman -Qi whoogle
Version : 0.6.0-5
Description : A self-hosted, ad-free, privacy-respecting metasearch engine
Architecture : x86_64
URL : https://github.com/benbusby/whoogle-search
Licenses : MIT
Groups : None
Provides : None
Depends On : python
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : whoogle-git
Replaces : None
Installed Size : 34.78 MiB
Packager : Chaotic-AUR Wild Bear Node <wildbear.node@chaotic.cx>
Build Date : Thu 21 Oct 2021 04:17:31 AM PDT
Install Date : Sun 12 Dec 2021 06:12:04 PM PST
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
─λ sudo systemctl status whoogle
● whoogle.service - Whoogle
Loaded: loaded (/usr/lib/systemd/system/whoogle.service; enabled; vendor preset: disabled)
Active: activating (auto-restart) (Result: exit-code) since Wed 2021-12-15 05:59:20 PST; 2s ago
Process: 592975 ExecStart=/opt/whoogle-search/venv/bin/python -um app --host $BIND_ADDRESS --port $LISTEN>
Main PID: 592975 (code=exited, status=1/FAILURE)
EDIT:
Never mind just got your reply on github.
REEDIT:
For those that don't want to wait for the Whoogle fix use the whoogle-git version in the Chaotic-AUR. It builds without any issues. You will need to restart the Whoogleservice once built.
