Internet speed 1/100th of what it was
Hello everyone I have recently encountered an issue with my installation. I used to get approximately 500 mb/s down and now it has plummeted to around 20 mb/s. I have tried going back to an earlier snapshot to no avail.
What I have tried
  1. Rebooted
  2. Restarted network manager
  3. Configured wifi to use 5 Ghz - even though my router offers it the system will not recognize the 5 ghz band. I am unsure if it has always been like this or if this is recent
  4. Rebooted to previous snapshot
What I haven’t tried
Installing different drivers for the network adapter. I do not know how to do this and do not want to break anything before asking for help.
Any help would be appreciated.
LANGUAGE = "",
LC_ALL = (unset),
LC_CTYPE = (unset),
LC_NUMERIC = "en_US.UTF-8",
LC_COLLATE = (unset),
LC_TIME = "en_GB.UTF-8",
LC_MESSAGES = (unset),
LC_MONETARY = "en_US.UTF-8",
LC_ADDRESS = "en_US.UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8",
LC_MEASUREMENT = "en_US.UTF-8",
LC_PAPER = "en_US.UTF-8",
LC_TELEPHONE = "en_US.UTF-8",
LC_NAME = "en_US.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
root=UUID=9613693f-dd5c-41e6-afd3-5bc2c13b93e5 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: Z790I AORUS ULTRA v: -CF
Mobo: Gigabyte model: Z790I AORUS ULTRA v: x.x
Megatrends LLC. v: F10b date: 12/04/2024
Info: model: Intel Core i7-14700K bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x12F
Topology: cpus: 1x dies: 1 clusters: 11 cores: 20 threads: 28 mt: 8 tpc: 2
st: 12 smt: enabled cache: L1: 1.8 MiB desc: d-12x32 KiB, 8x48 KiB; i-8x32
KiB, 12x64 KiB L2: 28 MiB desc: 8x2 MiB, 3x4 MiB L3: 33 MiB desc: 1x33 MiB
Speed (MHz): avg: 800 min/max: 800/5500:5600:4300 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 25: 800 26: 800 27: 800 28: 800 bogomips: 191385
Device-1: NVIDIA GA104 [GeForce RTX 3070] driver: nvidia v: 575.64
alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current (as of
2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2484
Monitor-1: DP-3 model: Dell AW3418DW serial: <filter> built: 2018 res:
mode: 3440x1440 hz: 120 scale: 100% (1) dpi: 109 gamma: 1.2
size: 798x335mm (31.42x13.19") diag: 865mm (34.1") modes: max: 3440x1440
min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
API: Vulkan v: 1.4.313 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 575.64 device-ID: 10de:2484
surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 20.1.6 256 bits)
driver: mesa llvmpipe v: 25.1.4-arch1.1 (LLVM 20.1.6)
Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
Device-3: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a014 class-ID: 0300
API: ALSA v: k6.15.3-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Raptor Lake-S PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0033
Local Storage: total: 5.46 TiB used: 640.9 GiB (11.5%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 47.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion Desk
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 0911 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 640.9 GiB (34.4%)
used: 624 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 640.9 GiB (34.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.1 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.0 C mobo: 48.0 C
Memory: total: 32 GiB note: est. available: 31.1 GiB used: 4.58 GiB (14.7%)
Processes: 517 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.36 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1989 libs: 558 tools: octopi,paru Compilers:
clang: 20.1.6 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date:     2025-03-02
Last full system update: 2025-06-25
WLAN or LAN connection?
Where did you get the result?
Did you check bit and bytes “problem” (500=62,5)
Install speedtest++ and check
ISP problem?
There have been many problems since a recent update to the linux-firmware package.
You might want to try running the following command in the terminal:
sudo pacman -Rdd linux-firmware && sudo pacman -S linux-firmware linux-firmware-intel
Welcome to the Garuda community BTW. :waving_hand: :smiley:
This is for a WLAN. My other non-linux devices are still getting around 500 down. I tested with speedtest++.
So this ended up working. Do you know what was in the update that might have caused this to occur?
Also thank you for the welcome!
