It was noticeable during video streaming and VNC connection. The cable is fine. The speed drops to zero sometimes for a second, sometimes for a few.
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-zen
root=UUID=b1d19ba0-d1ef-4640-8b83-51d3d5c0c767 rw quiet quiet splash
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20236 v: Lenovo G500
serial: <superuser required> Chassis: type: 10 v: Lenovo G500
Mobo: LENOVO model: INVALID v: 00000000Not Defined
serial: <superuser required> UEFI: LENOVO v: 78CN19WW(V1.07)
date: 07/04/2013
ID-1: BAT1 charge: 9.6 Wh (32.5%) condition: 29.5/40.4 Wh (73.0%)
volts: 10.7 min: 10.8 model: LENOVO PABAS0241231 type: Li-ion
Info: model: Intel Core i5-3230M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1555 high: 1753 min/max: 1200/3200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1753 2: 1563 3: 1567
4: 1337 bogomips: 20753
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: AMD Sun PRO [Radeon HD 8570A/8570M] vendor: Lenovo
driver: radeon v: kernel alternate: amdgpu pcie: gen: 3 speed: 8 GT/s
lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6663 class-ID: 0380
Device-3: Acer Lenovo Integrated Webcam type: USB driver: uvcvideo
bus-ID: 3-4:2 chip-ID: 5986:0295 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting,radeon alternate: fbdev,intel,vesa gpu: i915
display-ID: :0.0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: LG Display 0x033a built: 2011 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Qualcomm Atheros QCA8172 Fast Ethernet vendor: Lenovo driver: alx
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
chip-ID: 1969:10a0 class-ID: 0200
IF: enp2s0 state: up speed: 10 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Lenovo driver: N/A pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:4365
Device-1: Foxconn BCM43142A0 Bluetooth module type: USB driver: btusb
v: 0.8 bus-ID: 1-1.3:4 chip-ID: 105b:e065 class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 223.57 GiB used: 35.33 GiB (15.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: AMD Radeon model: R3SL240G
type: SSD serial: <filter> rev: 2C scheme: GPT
ID-1: / raw-size: 86.33 GiB size: 84.42 GiB (97.79%)
used: 35.33 GiB (41.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 330 MiB size: 329.3 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-1: swap-1 type: zram size: 15.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C mobo: N/A gpu: radeon temp: 44.0 C
Processes: 227 Uptime: 1h 8m wakeups: 1 Memory: 15.49 GiB
used: 2.55 GiB (16.5%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1681 apt: 1 pacman: 1680 lib: 403
flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-22
Last full system update: 2022-05-23 ↻
Failed units: snapper-cleanup.service systemd-networkd-wait-online.service
