When I upgraded Plasma to 5.22, network manager stopped working on my laptop. When checking in terminal, the Wi-Fi hardware seemed to be up and running, but I did not have a connection. I ended up with a corrupted system and was not able to recover with Timeshift. I choose to reinstall the system. After the initial update, I got the same issue. This time I was able to recover the system to its original state and excluded Network manager from my upgrade list. This worked.
Has anyone experienced the same issue?
Side note: I did not experience this on my desktop. Only my laptop.
Kernel: 5.10.43-1-lts x86_64 bits: 64
compiler: gcc v: 11.1.0
root=UUID=355a9e98-853f-4627-a61b-91a49ba87cb4
rw [email protected] quiet splash
rd.udev.log_priority=3
vt.global_cursor_default=0
Console: tty pts/0 wm: kwin_x11 DM: SDDM
Type: Desktop Mobo: N/A model: N/A serial: N/A
UEFI: American Megatrends
v: E.G140J.D8.E1.016.bin date: 11/29/2019
ID-1: BAT0 charge: 24.1 Wh (85.2%)
condition: 28.3/38.0 Wh (74.5%) volts: 7.6
min: N/A model: GLK MRD Li-ion Battery
type: Li-ion serial: <filter>
status: Discharging
Info: Quad Core model: Intel Celeron N4100
bits: 64 type: MCP arch: Goldmont Plus
family: 6 model-id: 7A (122) stepping: 1
microcode: 36 cache: L1: 224 KiB L2: 4 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2
ssse3 vmx
bogomips: 8755
Speed: 2288 MHz min/max: 800/2400 MHz
base/boost: 1100/2700 volts: 1.2 V
ext-clock: 100 MHz Core speeds (MHz): 1: 2288
2: 2288 3: 2288 4: 2288
Vulnerabilities: Type: itlb_multihit
status: Not affected
Type: spec_store_bypass mitigation: Speculative
Store Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs
barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Enhanced IBRS,
IBPB: conditional, RSB filling
Device-1: Intel UHD Graphics 605 driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3185
Device-2: Microdia Webcam Vitade AF type: USB
driver: uvcvideo bus-ID: 1-7:4
chip-ID: 0c45:6366 class-ID: 0e02
Display: server: X.Org 1.20.11
compositor: kwin_x11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
s-size: 508x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157
size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL:
renderer: Mesa Intel UHD Graphics 600 (GLK 2)
v: 4.6 Mesa 21.1.2 direct render: Yes
Device-1: Intel Celeron/Pentium Silver
Processor High Definition Audio
vendor: Realtek driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:0e.0 chip-ID: 8086:3198
Sound Server-1: ALSA v: k5.10.43-1-lts
running: yes
Sound Server-4: PipeWire v: 0.3.30
running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi
v: kernel port: f040 bus-ID: 01:00.0
chip-ID: 8086:095a class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-1: Intel Bluetooth wireless interface
type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0
state: up address: <filter>
Local Storage: total: 238.47 GiB
used: 95.02 GiB (39.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Netac
model: SSD 256GB size: 238.47 GiB block-size:
physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 2A0 temp: 40 C scheme: GPT
SMART: yes state: enabled health: PASSED
on: 33d 4h cycles: 850 read: 26.2 MiB
written: 30.2 MiB
ID-1: / raw-size: 39.06 GiB
size: 39.06 GiB (100.00%)
used: 13.03 GiB (33.3%) fs: btrfs
block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 515 MiB
size: 514 MiB (99.80%) used: 560 KiB (0.1%)
fs: vfat block-size: 512 B dev: /dev/sda3
maj-min: 8:3
ID-3: /home raw-size: 191.41 GiB
size: 187.4 GiB (97.91%) used: 82 GiB (43.8%)
fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 39.06 GiB
ID-5: /var/tmp raw-size: 39.06 GiB
Kernel: swappiness: 10 (default 60)
cache-pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 7.5 GiB
used: 0 KiB (0.0%) priority: -2 dev: /dev/sda4
maj-min: 8:4
ID-2: swap-2 type: zram size: 1.9 GiB
used: 0 KiB (0.0%) priority: 32767
ID-3: swap-3 type: zram size: 1.9 GiB
dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.9 GiB
dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.9 GiB
dev: /dev/zram3
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 225 Uptime: 22m wakeups: 1
Memory: 7.59 GiB used: 3.58 GiB (47.2%)
Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.0 Packages:
pacman: 1406 lib: 344 Shell: fish (sudo)
v: 3.2.2 default: Bash v: 5.1.8
running-in: alacritty inxi: 3.3.04
