Hello,
I’ve used garuda linux dr460nized for a couple months now and i’ve always had problems staying connected to the internet, when it is connected it tends to be extremely slow and laggy. I’ve tried every fix i saw here as well as on the arch linux forum, with nothing seeming to work despite speed tests usually returning with 50-60MBPS, and never seeing this problem before i switched to garuda linux.
Here’s my inxi:
Kernel: 6.6.61-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=e6fa36a8-26d4-4fb6-9b69-abe3c3643fd2 rw rootflags=subvol=@
loglevel=3 pcie_aspm=off quiet pcie_aspm.policy=performance
ipv6.disable=1 ibt=off
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 1407 date: 04/01/2020
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 1+
model-id: 8 stepping: 2 microcode: 0x800820D
smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2196 min/max: 2200/3800 boost: disabled scaling:
driver: acpi-cpufreq governor: powersave cores: 1: 2196 2: 2196 3: 2196
4: 2196 5: 2196 6: 2196 7: 2196 8: 2196 9: 2196 10: 2196 11: 2196 12: 2196
bogomips: 91231
Device-1: NVIDIA GP104 [GeForce GTX 1070] driver: nvidia v: 565.57.01
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DP-2,DP-3,HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 09:00.0
chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
Screen-1: 0 s-res: 3840x2160 s-dpi: 144 s-size: 679x382mm (26.73x15.04")
s-diag: 779mm (30.67")
Monitor-1: not-matched mapped: DP-3 pos: top-right res: 1920x1080 hz: 60
dpi: 96 size: 509x286mm (20.04x11.26") diag: 584mm (22.99") modes: N/A
Monitor-2: not-matched mapped: DP-5 pos: bottom-c res: 1920x1080 hz: 60
dpi: 141 size: 345x195mm (13.58x7.68") diag: 396mm (15.6") modes: N/A
Monitor-3: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,top-left
model: D32f-E1 serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 70
gamma: 1.2 size: 698x392mm (27.48x15.43") diag: 801mm (31.5") ratio: 16:9
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 565.57.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.295 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 565.57.01
device-ID: 10de:1b81 surfaces: xcb,xlib
Device-1: NVIDIA GP104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:10f0
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK
bus-ID: 0b:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-3.3:4 chip-ID: 0c76:161e class-ID: 0300
Device-4: Razer USA Kraken X USB driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.4:5
chip-ID: 1532:0526 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.61-1-lts status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel modules: wl pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723
Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel modules: wl pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8168 v: 8.054.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
Device-4: NetGear A6210 driver: mt76x2u type: USB rev: 2.1 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 5-2:3 chip-ID: 0846:9053 class-ID: 0000
IF: wlp10s0f3u2 state: up mac: <filter>
Info: services: NetworkManager, smbd, systemd-networkd,
systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 8087:0029
Device-2: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:3
Report: ID: hci1 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 1.36 TiB used: 1.14 TiB (83.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: Portable
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 0712 scheme: MBR
used: 409.7 GiB (88.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 48.6 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 34%
Memory: total: 16 GiB available: 15.54 GiB used: 2.78 GiB (17.9%)
Processes: 402 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,upowerd
Packages: 1819 pm: pacman pkgs: 1807 libs: 542
tools: octopi,paru,trizen,yay pm: flatpak pkgs: 12 Compilers: clang: 18.1.8
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.36
System install date: 2024-07-22
Last full system update: 2024-11-16
