Hello, i can’t get my wifi to work =(
pls help!
lspci -knn | grep Network -A3
03:00.0 Network controller [0280]: Intel Corporation Wi-Fi 5(802.11ac) Wireless-AC 9x6x [Thunder Peak] [8086:2526] (rev 29)
Subsystem: Intel Corporation Dual Band Wi-Fi 5 Wireless-AC 9260 160MHz 2x2 [8086:0014]
Kernel modules: iwlwifi
sudo lshw -class network
*-network UNCLAIMED
description: Network controller
product: Wi-Fi 5(802.11ac) Wireless-AC 9x6x [Thunder Peak]
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: 29
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: memory:fd500000-fd503fff
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: N/A
modules: iwlwifi pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
lsmod | grep -e wl -e iwlwifi
iwlwifi 651264 0
cfg80211 1441792 2 brcmfmac,iwlwifi
sudo modprobe iwlwifi is not working ='(
hello and welcome,
Did you using Windows in Dual Boot with Garuda?
Can you try shutdown windows correctly you can do with pressed shift button to shutdown. My windows was hijacking the wifi module if i did not correctly.
Please also post your garuda-inxi. The iwlwifi driver should detect your Device.
no dual boot, just garuda
here’s the garuda-inxi. says Driver: N/A
nepti
9 June 2025 18:13
4
Please post the full output of your garuda-inxi
. Thanks.
Which Kernel you are using? Is your Bios up to date? Did you checked that wifi is enabled in the Bios Settings? We need the full inxi.
What you mean by it sudo modprobe iwlwifi is not working ='(
did it shows any error?
Maybe you try to reset the Bios ?
can you check if its blocked?
rfkill list
you also can check if you have the sudo pacman -S linux-firmware
package installed. It is preinstalled normally.
Please post your full garuda-inxi
output, so that we don’t need to play a game of 50 questions, such as:
What kernel are you using?
Which Garuda edition are you using?
Yada
Yada
Yada…
The best suggestions for you have already been put forth. Start by updating or reseting your bios, and test alternate kernels.
If we don’t receive your full garuda-inxi
on your next post, your help request will likely be dust binned. Your full specs from a garuda-inxi
are a requirement to receive assistance on the Garuda forum.
Your full cooperation would be greatly appreciated.
tbg:
Kernel: 6.14.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=70297890-4705-403a-8aba-b1b5272967c0 rw rootflags=subvol=@
quiet resume=UUID=5aadd350-ff93-4e3e-bbdf-a012fa557f3f loglevel=3 ibt=off
Mobo: ASUSTeK model: ROG ZENITH EXTREME ALPHA v: Rev 1.xx
UEFI: American Megatrends v: 2701 date: 02/02/2024
Info: model: AMD Ryzen Threadripper 2970WX bits: 64 type: MT MCP arch: Zen+
gen: 1+ level: v3 note: check built: 2018-21 process: GF 12nm
Topology: cpus: 1x dies: 1 clusters: 1 cores: 24 threads: 48 tpc: 2
smt: enabled cache: L1: 2.2 MiB desc: d-24x32 KiB; i-24x64 KiB L2: 12 MiB
desc: 24x512 KiB L3: 64 MiB desc: 8x8 MiB
Speed (MHz): avg: 2200 min/max: 2200/3000 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200
21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200 28: 2200
29: 2200 30: 2200 31: 2200 32: 2200 33: 2200 34: 2200 35: 2200 36: 2200
37: 2200 38: 2200 39: 2200 40: 2200 41: 2200 42: 2200 43: 2200 44: 2200
45: 2200 46: 2200 47: 2200 48: 2200 bogomips: 287967
Device-1: NVIDIA AD107 [GeForce RTX 4060] vendor: Micro-Star MSI
driver: nvidia v: 575.57.08 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s ports: active: none
off: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 43:00.0 chip-ID: 10de:2882
Device-2: Alcorlink USB 2.0 Camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 9-1:2
chip-ID: 2ce3:c670 class-ID: 0102
d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-1 pos: primary,left model: 27E6QC serial: <filter>
built: 2022 res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 108 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: DP-3 pos: right model: 27E6QC serial: <filter> built: 2022 res:
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.57.08
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060/PCIe/SSE2
API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4060 driver: nvidia v: 575.57.08
device-ID: 10de:2882 surfaces: N/A
Device-1: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK
bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-2: NVIDIA AD107 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 43:00.1 chip-ID: 10de:22be
Device-3: Alcorlink USB 2.0 Camera driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.14.10-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 05:00.0
Device-3: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic
10G] vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 link-max: lanes: 4 port: N/A bus-ID: 09:00.0 chip-ID: 1d6a:07b1
class-ID: 0200 temp: 60.3 C
IF-ID-1: tun0 state: down mac: <filter>
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
Local Storage: total: 4.91 TiB used: 67.5 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV3S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: ERFK1N.3 temp: 44.9 C
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Kingston model: SNV3S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: ERFK1N.3 temp: 45.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: A-Data model: SU650 size: 894.25 GiB
serial: <filter> fw-rev: 1c55 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU650 size: 894.25 GiB
serial: <filter> fw-rev: 1c64 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: A-Data model: SX930 size: 447.13 GiB
serial: <filter> fw-rev: E scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Samsung model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 2AR1 scheme: GPT
ID-1: / raw-size: 862.2 GiB size: 862.2 GiB (100.00%) used: 67.5 GiB (7.8%)
fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 616 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 862.2 GiB size: 862.2 GiB (100.00%)
used: 67.5 GiB (7.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
ID-4: /var/log raw-size: 862.2 GiB size: 862.2 GiB (100.00%)
ID-5: /var/tmp raw-size: 862.2 GiB size: 862.2 GiB (100.00%)
ID-1: swap-1 type: partition size: 69.02 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:5
ID-2: swap-2 type: zram size: 62.74 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 48
System Temperatures: cpu: 55.6 C mobo: 42.0 C sodimm: 216.0 C
Fan Speeds (rpm): cpu: 2700 case-1: 0 case-2: 1415
Power: 12v: 14.58 5v: N/A 3.3v: N/A vbat: 3.16
Memory: total: 64 GiB available: 62.74 GiB used: 8.75 GiB (14.0%)
Processes: 793 Power: uptime: 1h 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.01 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2087 libs: 512 tools: octopi,paru Compilers:
clang: 20.1.6 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date: 2025-06-08
Last full system update: 2025-06-09 ↻
tried enablling/disabling it on the BIOS
here’s rfkill list output
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Reboot and try again, maybe it help.
Like @SGS already mentioned reboot first.
If it not helps i would power off the pc and unplug the Power Cord and press few times the power button to empty the capasitors if a bios reset not working.
There is a newer dated version of your bios firmware but its same version 2701.
ROG Zenith Alpha
you also can try to install the lts kernel over Garuda-Rani - System settings- Kernel
or over terminal sudo pacman -S linux-lts linux-lts-headers
brcmfmac
is a Broadcom wifi driver/module it should not be showing in your lsmod
output. Did you install any Broadcom wifi driver/firmware package? If you have, be sure to uninstall that package. You can also try rmmodding
the brcmfmac
module.
You have edited your prior posts. I thought you said you tested the LTS kernel, if not be sure you also test the LTS kernel as well.
Hello!
how do i remove the brcmfmac driver? i can’t seem to find any package with the name brcmfmac tru pacman
It is likely being loaded as a kernel module, try:
sudo modprobe -rv brcmfmac
sudo lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs sudo rmmod
thank you! i managed to remove brcmfmac
sudo modprobe runs with no errors but the wifi adapter isn’t working. i know it works because i can use it on ubuntu live..
im gonna try and poweroff / disconnect my PC as someone suggested on a reply above..
Thank you very much
iwlwifi 651264 0
cfg80211 1441792 1 iwlwifi
Be sure to also disconnect your Ethernet cable, and don’t plug it back in right away.
it’s working!
wifi interface is fixed after reboot / disconnect
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
IF: wlan0 state: down mac: <filter>
Thank you all for the assistance!
system
Closed
11 June 2025 23:56
17
