hello guys, i really new to the Linux OS and i find it hard understanding it...
uhmm please help me,
I installed Garuda alongside my windows 10 recently and the windows is lo longer working
and also i cant connect the OS to wireless network, it says wireless deactivated please any solution?
Can you provide you
as per the forum template
even if it is from the live usb
And if its not working in windows it might be broken adapter
okay is it possible to delete the windows OS using garuda now that i cannot access the windows?
╭─linus@linus in ~ via v3.10.4
╰─λ garuda-inxi
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=78d66672-7a6b-441e-9d71-9f35b6dbc018 rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 2537LB8 v: ThinkPad T410
Mobo: LENOVO model: 2537LB8 serial: <superuser required> BIOS: LENOVO
v: 6IET65WW (1.25 ) date: 06/07/2010
ID-1: BAT0 charge: 13.1 Wh (85.6%) condition: 15.3/48.8 Wh (31.3%)
volts: 11.7 min: 11.1 model: SANYO 42T4832 type: Li-ion serial: <filter>
Info: model: Intel Core i5 M 520 bits: 64 type: MT MCP arch: Westmere
family: 6 model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1569 high: 1708 min/max: 1199/2400 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1521 2: 1503
3: 1708 4: 1544 bogomips: 19152
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel ports: active: LVDS-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.00x9.37")
s-diag: 449mm (17.69")
Monitor-1: LVDS-1 model: Lenovo 0x4036 built: 2009 res: 1440x900 hz: 60
dpi: 121 gamma: 1.2 size: 303x189mm (11.93x7.44") diag: 357mm (14.1")
ratio: 16:10 modes: 1440x900
OpenGL: renderer: Mesa Intel HD Graphics (ILK) v: 2.1 Mesa 22.0.2
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
Device-1: Intel 82577LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: 1820 bus-ID: 00:19.0 chip-ID: 8086:10ea class-ID: 0200
Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:4239
IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 149.05 GiB used: 36.74 GiB (24.6%)
model: WD1600BEVT-60ZCT1 size: 149.05 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A13 scheme: MBR
ID-1: / raw-size: 148.51 GiB size: 148.51 GiB (100.00%)
used: 36.74 GiB (24.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /home raw-size: 148.51 GiB size: 148.51 GiB (100.00%)
ID-3: /var/log raw-size: 148.51 GiB size: 148.51 GiB (100.00%)
ID-4: /var/tmp raw-size: 148.51 GiB size: 148.51 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.56 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3806
Processes: 230 Uptime: 53m wakeups: 1 Memory: 7.56 GiB
used: 3.19 GiB (42.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1676 lib: 507 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
error: GPGME error: No data
Garuda (2.6.2-1):
System install date: 2022-05-09
Last full system update: 2022-05-09
Failed units: bluetooth-autoconnect.service systemd-vconsole-setup.service
╭─linus@linus in ~ via v3.10.4 took 2s
Welcome to the forums
In Linux everything is possible you can also try
sudo update-grub
or first
garuda-update
May it is better you start with a linux for new comers, like MX Linux.
We do not teach new linux users and dual boot with M$ is not supported by the Garuda Team.
3 posts were split to a new topic: Garuda-inxi - Windows detection question
I would recommend disabling fast boot on Windows.
I would also recommend resetting your bios to the factory default if my prior suggestion is of no improvement. You will likely need to modify your BIOS settings for use with Linux after resetting your bios. Be sure both secure boot and fast boot are disabled in the BIOS. Also be sure your controller is set to AHCI mode in your BIOS.
I would also suggest testing out the linux-lts
kernel as your hardware is rather old. Testing other kernels may also be helpful to get your wifi working.
Please run these commands:
sudo ip link set dev wlp3s0 up
rfkill list
Please post both the inputs and output of those commands.
