Intel Management Engine update under Garuda Linux
Hi Everyone!
Have any of you updated the Intel ME software / version on your motherboard while on Garuda Linux and not dual booting with Windows? How did you accomplish that? I'm looking to update the motherboard BIOS on ASUS ROG Strix Z690-E since it's few versions behind but the instructions that ASUS provides are that the Intel Management Engine must be up to date first before the BIOS can be updated. ASUS provides an installer to do this under Windows but that doesn't help those who moved on. Please share any info or experience you have on this topic.
Thanks so much.
Kernel: 6.4.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=caed606e-7d5e-4429-b887-10d54dbe5b65 rw rootflags=subvol=@
quiet rd.luks.uuid=6db6651f-a1bf-4f4e-8146-95b74b2b5b32 quiet
Mobo: ASUSTeK model: ROG STRIX Z690-E GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2305
date: 03/10/2023
Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
microcode: 0x2C
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 2216 high: 2500 min/max: 800/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 2500 2: 2500 3: 2500
4: 2500 5: 2500 6: 2500 7: 800 8: 2500 9: 2500 10: 2500 11: 800 12: 2500
bogomips: 59904
Device-1: AMD Hawaii XT / Grenada [Radeon R9 290X/390X] vendor: ASUSTeK
driver: radeon v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 ports: active: DP-1
empty: DVI-D-1,DVI-D-2,HDMI-A-1 bus-ID: 0000:01:00.0 chip-ID: 1002:67b0
Device-2: Logitech Camera (Notebooks Pro) driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.1:6
chip-ID: 046d:08c3 class-ID: 0102
alternate: fbdev,vesa dri: radeonsi gpu: radeon display-ID: :0 screens: 1
s-diag: 1165mm (45.88")
Monitor-1: DP-1 mapped: DisplayPort-0 model: ViewSonic VP3256-4K
serial: <filter> built: 2021 res: 3840x2160 hz: 60 dpi: 140 gamma: 1.2
max: 3840x2160 min: 720x400
API: OpenGL v: 4.5 Mesa 23.1.5 renderer: HAWAII ( LLVM 15.0.7 DRM 2.50
6.4.8-zen1-1-zen) direct-render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
Device-2: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1
chip-ID: 1002:aac8 class-ID: 0403
Device-3: Harman JBL Pebbles driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11.1.2:12
chip-ID: 05fc:0231 class-ID: 0300 serial: <filter>
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2
chip-ID: 0b05:1996 class-ID: 0300
Device-5: Logitech Camera (Notebooks Pro) driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.4.8-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
bus-ID: 0000:04:00.0 chip-ID: 8086:2725 class-ID: 0280
port: N/A bus-ID: 0000:06:00.0 chip-ID: 8086:15f3 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0032
address: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 1.82 TiB used: 17.57 GiB (0.9%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 043 scheme: GPT
ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
used: 17.57 GiB (1.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-6db6651f-a1bf-4f4e-8146-95b74b2b5b32
ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-4: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A gpu: radeon temp: 50.0 C
Processes: 360 Uptime: 3m wakeups: 0 Memory: total: 32 GiB
available: 31.16 GiB used: 2.7 GiB (8.6%) Init: systemd v: 254
pm: pacman pkgs: 1531 libs: 400 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date:     2023-08-06
Last full system update: 2023-08-06
You usually don't need to update your firmware like BIOS or Intel ME version unless you are facing unexplainable errors that can't be traced or your manufacturer has released Critical updates that concern patching security of your system.
Once out of that, there are two ways to do that, one is using windows PE
https://wiki.archlinux.org/title/Windows_PE#Update_Intel_Management_Engine_firmware
not full blown windows os but gets the job done all from a usb stick. Second is using fwupd (link to that in the article above)
"hi! for some inexplicable/insane reason i need help to fix the NSA's back door into my hardware's subsystem!" =-P
