I recently downloaded the latest version of garuda ISO. And this issue is driving me nuts.
I am using the machine normally, suddently my internet connection dies - nothing I can do brings it up again, plugin the cable, creating a new connection. The only way is to reboot the whole machine, and voila it works. It took me 2 days to realize it was not my ISP and the machine losing connection because, it was working flawlessly before the new iso install.
One interesting bit, is that it seems to be 1hours intervals or close to.
If I ping anything, it tells me it failed to resolve the host name - changed DNS, same result, done it multiple time times, with multiple DNS.
I cant afford to do a fresh install right now, what can I do to fix this?
root=UUID=6598ddea-ecba-4898-822f-5cfb699ebea5 rw rootflags=subvol=@
amd_iommu=on iommu=pt rd.driver.pre=vfio-pci
vfio-pci.ids=10de:2684,10de:22ba ibt=off
Desktop: Hyprland vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX X670E-E GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0922
date: 02/23/2023
ID-1: hidpp_battery_0 charge: 85% condition: N/A volts: 4.0 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
Info: model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4 gen: 5
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1090 high: 5499 min/max: 400/5881 scaling:
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 4609
14: 400 15: 400 16: 400 17: 4341 18: 5499 19: 400 20: 400 21: 400 22: 400
23: 400 24: 400 25: 400 26: 400 27: 400 28: 5126 29: 400 30: 4532 31: 400
32: 400 bogomips: 288003
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: ASUSTeK driver: vfio-pci
v: N/A alternate: nouveau,nvidia_drm,nvidia non-free: 545.xx+
status: current (as of 2023-10) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2684 class-ID: 0300
Device-2: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia
v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.0
chip-ID: 10de:1b80 class-ID: 0300
Device-3: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1
bus-ID: 13:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 45.0 C
compositor: Hyprland driver: X: loaded: amdgpu,nvidia
gpu: amdgpu display-ID: 1
Monitor-1: HDMI-A-1 model: LG (GoldStar) TV SSCR2 serial: <filter>
built: 2020 res: 3840x2160 hz: 120 dpi: 61 gamma: 1.2 scale: 1
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
API: Vulkan v: 1.3.269 layers: 4 device: 0 type: integrated-gpu name: AMD
v: 23.2.1-arch1.2 device-ID: 1002:164e surfaces: xcb,xlib,wayland
device: 1 type: discrete-gpu name: NVIDIA GeForce GTX 1080 driver: nvidia
v: 535.113.01 device-ID: 10de:1b80 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
Device-1: NVIDIA AD102 High Definition Audio vendor: ASUSTeK
driver: vfio-pci alternate: snd_hda_intel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:22ba
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
link-max: lanes: 16 bus-ID: 05:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 13:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-4: C-Media USB Advanced Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 0d8c:016c class-ID: 0300
Device-5: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:5
Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2725
IF: wlp9s0 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0032
Local Storage: total: 6.94 TiB used: 16.79 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT303.3 temp: 28.9 C
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 37.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDHP256G
tech: SSD serial: <filter> fw-rev: 6RL scheme: GPT
model: WD3200BPVT-80JJ5T0 size: 298.09 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: HD103UI
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 1113 scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST3000DM001-1ER166
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
ID-1: / raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
used: 16.79 GiB (3.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:8
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:7
ID-3: /home raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-4: /var/log raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-5: /var/tmp raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-1: swap-1 type: zram size: 61.94 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 55.2 C mobo: N/A gpu: amdgpu temp: 46.0 C
Processes: 568 Uptime: 2m wakeups: 0 Memory: total: 64 GiB
available: 61.94 GiB used: 4.03 GiB (6.5%) Init: systemd v: 254
pm: pacman pkgs: 1369 libs: 379 tools: pamac,paru,yay Shell: fish v: 3.6.1
running-in: alacritty inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-11-01
Last full system update: 2023-11-02
