I have been having this issue couple past weeks. Ethernet will keep disconnecting and connecting. It should not be a HW issue because when I booted to windows on same machine it worked fine. This usually happens right after boot but can sometimes happen randomly during usage. Dmesg is not very helpful al all…
[ 0.000000] efi: Not removing mem72: MMIO range=[0xfec00000-0xfec00fff] (4KB) - Pastebin.com dmesg log
Kernel: 6.13.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=657901d0-2af4-4b27-83f9-ebc013c73770 rw rootflags=subvol=@
quiet rd.luks.uuid=1142304e-afaf-4a1e-bffc-7b1e5da946cf quiet
usbcore.autosuspend=-1 ibt=off
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Mobo: ASUSTeK model: PRIME H510M-A v: Rev 1.xx serial: <filter>
part-nu: SKU uuid: 7e879200-015f-fb0e-cec7-fc34971214b0
UEFI: American Megatrends v: 0404 date: 02/05/2021
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
Info: model: Intel Core i7-10700K socket: LGA1200 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 5
microcode: 0xFC
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5100 base/boost: 3762/5100 scaling:
driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800 bogomips: 121596
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: DP-1,HDMI-A-1 empty: DP-2,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc5 class-ID: 0300
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DP-1 pos: right model: Asus VE247 serial: <filter> built: 2014
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 pos: primary,left model: Asus VE247 serial: <filter>
built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CML
GT2) device-ID: 8086:9bc5 memory: 15.2 GiB unified: yes
API: Vulkan v: 1.4.304 layers: 5 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CML GT2) driver: N/A device-ID: 8086:9bc5
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
API: ALSA v: k6.13.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.1 status: n/a (root, process) with:
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
Local Storage: total: 465.76 GiB used: 287.39 GiB (61.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 34.9 C
SMART: yes health: PASSED on: 1y 189d 1h cycles: 246
read-units: 23,897,581 [12.2 TB] written-units: 13,959,925 [7.14 TB]
ID-1: / raw-size: 363.49 GiB size: 363.49 GiB (100.00%)
used: 287.18 GiB (79.0%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-1142304e-afaf-4a1e-bffc-7b1e5da946cf
ID-2: /boot raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 220.3 MiB (21.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p7
maj-min: 259:7
ID-4: /home raw-size: 363.49 GiB size: 363.49 GiB (100.00%)
ID-5: /var/log raw-size: 363.49 GiB size: 363.49 GiB (100.00%)
ID-6: /var/tmp raw-size: 363.49 GiB size: 363.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.13 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 31.0 C mobo: N/A
Memory: total: 32 GiB available: 31.13 GiB used: 8.44 GiB (27.1%)
igpu: 64 MiB
Processes: 371 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1668 libs: 449 tools: pakku,paru,yay Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
System install date: 2023-06-08
Last full system update: 2025-03-19
Is partially upgraded: Yes
Windows dual boot: Yes
Failed units: mnt-bach-bachdata.mount mnt-bach-servis.mount mnt-bach-temp.mount
