Hey folks,
I recently uploaded my hw-probe
to the Hardware for Linux website:
Scrolling down, you’ll notice the entry for Alder Lake-S PCH HECI Controller #1 as having a “failed” status. I dug around a bit, and this is related to the integrated intel hda which is in fact, not working on my system. I discovered this a few months ago when I plugged-in a headset into the front Mic and Headphone ports and nothing happened - no detection from the system, no audio at all. I played around with pipewire thinking it might be related to that, but it was consistently not displaying the integrated audio hardware. I chalked it up to weird pipewire errata and moved on since the monitors have integrated speakers and I’m getting audio over DP (though the system is registering is as HDMI audio).
However, in light of the “failed” status - I’ve come to realize that in fact, the integrated audio is not working at all. I checked and confirmed that I do have the kernel modules loaded (a slew of intel_hda
appear in lsmod
) but clearly the system is showing that the integrated audio has failed via hw-probe
When typing lspci -k|grep intel
I get this output:
> lspci -k |grep intel
Kernel driver in use: intel_vsec
Kernel modules: intel_vsec
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
Kernel modules: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
Kernel driver in use: intel-spi
Kernel modules: spi_intel_pci
Kernel driver in use: snd_hda_intel
Typing aplay -Ll
doesn’t list the intel sound card at all, only the NVIDIA audio output.
I also ran sudo dmesg|grep 'snd|sof'
and the output is blank.
Here is my garuda-inxi
> garuda-inxi
Kernel: 6.16.8-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=8dcc0c9c-8fe9-4fc6-b189-a8db2cfa3823 rw rootflags=subvol=@
rd.driver.pre=vfio-pci intel_iommu=on i915.enable_guc=3 i915.max_vfs=7
quiet resume=UUID=a14a443b-9c6b-47d0-b49a-d9686d767b7c loglevel=3
sysrq_always_enabled=1 split_lock_detect=off nvidia-drm.modeset=1
pci=disable_acs_redir=pci:12D8:2308
Mobo: ASUSTeK model: PRIME Z690-P WIFI v: Rev 1.xx
UEFI: American Megatrends v: 3801 date: 05/14/2025
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP
microcode: 0x3A
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB
desc: 1x30 MiB
Speed (MHz): avg: 889 min/max: 800/5100:5200:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 889 2: 889 3: 889 4: 889
5: 889 6: 889 7: 889 8: 889 9: 889 10: 889 11: 889 12: 889 13: 889 14: 889
15: 889 16: 889 17: 889 18: 889 19: 889 20: 889 21: 889 22: 889 23: 889
24: 889 bogomips: 152985
Device-1: Intel AlderLake-S GT1 vendor: ASUSTeK driver: i915
v: 2025.07.22-sriov.6.12.39 alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: none empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
Device-2: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
vendor: ASUSTeK driver: nvidia v: 580.82.09 alternate: nouveau,nvidia_drm
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2,DP-4,HDMI-A-4
empty: DP-3,HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:2489 class-ID: 0300
Device-3: Microsoft LifeCam Studio
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 045e:0772
gpu: nv_platform,nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-2 pos: primary,left model: Samsung SyncMaster
serial: <filter> built: 2009 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
Monitor-2: DP-4 pos: right model: Dell UZ2715H serial: <filter>
built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 83 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 676mm (26.6") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-3: HDMI-A-4 pos: right model: ROG PG248Q serial: <filter>
built: 2020 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
API: Vulkan v: 1.4.321 layers: 17 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 580.82.09 device-ID: 10de:2489
surfaces: N/A device: 1 type: integrated-gpu name: Intel UHD Graphics 770
(ADL-S GT1) driver: mesa intel v: 25.2.3-arch1.2 device-ID: 8086:4680
surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM 20.1.8 256 bits)
driver: mesa llvmpipe v: 25.2.3-arch1.2 (LLVM 20.1.8)
de: kscreen-console,kscreen-doctor gpu: corectrl, gputop, intel_gpu_top,
lsgpu, lact, nvidia-settings, nvidia-smi wl: wayland-info,wlr-randr
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: vfio-pci
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl bus-ID: 00:1f.3
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
API: ALSA v: k6.16.8-zen3-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
IF-ID-1: br-1f7862558da6 state: down mac: <filter>
IF-ID-2: br-6e396916a229 state: down mac: <filter>
IF-ID-3: br-7bfc84ea431e state: down mac: <filter>
IF-ID-4: br-82d31aa0b51e state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: br-8cfdb6073e28 state: down mac: <filter>
IF-ID-6: br-960c3623af4c state: down mac: <filter>
IF-ID-7: br-b787944b7593 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-8: br-b90412b2529c state: down mac: <filter>
IF-ID-9: br-c3a5729d4cf6 state: down mac: <filter>
IF-ID-10: br-e0cf0c4bc03a state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-11: br-e9c38ec2b98c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-12: docker0 state: down mac: <filter>
IF-ID-13: veth828f3c6 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: vethed8a48f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: vethf229e7d state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: vethf741829 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: virbr0 state: down mac: <filter>
IF-ID-18: virbr1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0026
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 6.37 TiB used: 2.96 TiB (46.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 51.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 45.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NE001-2MA101
tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 697.71 GiB (38.2%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:3
used: 636 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:2
used: 697.71 GiB (38.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:3
maj-min: 259:3
maj-min: 259:3
ID-1: swap-1 type: zram size: 31.08 GiB used: 6.46 GiB (20.8%)
ID-2: swap-2 type: partition size: 34.2 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
System Temperatures: cpu: 47.5 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.08 GiB
used: 12.44 GiB (40.0%)
Processes: 730 Power: uptime: 1d 2h 54m states: freeze,mem,disk
reboot, suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
Packages: 2719 pm: pacman pkgs: 2708 libs: 617 tools: octopi,pacseek,paru
pm: flatpak pkgs: 11 Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 13/14
Shell: Bash v: 5.3.3 default: fish v: 4.0.8 running-in: kitty inxi: 3.3.39
Garuda (2.8.3-2):
System install date: 2024-10-16
Garuda release: 240428
Last full system update: 2025-09-26
23/24 checks run in 0.80 seconds ⌛
Powered by garuda-health 🦅
Of course, I’ve searched online, and the only “solved” thread on the arch bbs was to install sof-firmware
which is already installed.
If anyone has any ideas, please send 'em my way!
Thank you!
Edit: Loading up all entries for this PCI ID that have been submitted to linux-hardware.org:
All the ones listed at the bottom have a “failed” status and they’re all “Garuda” distributions.
At the top of the page, under “Kernel drivers”, there’s a column titled “Config” with CONFIG_INTEL_MEI CONFIG_INTEL_MEI_ME
listed. Is this a kernel configuration option that needs to be turned on when compiling the zen kernel? I’m only installed pre-compiled linux-zen - though I imagine it’s enabled in the kernel by default. Would I need to compile my own version of the linux-zen kernel with one or both those config options set to y
