I am attempting to install Garuda Linux Dragonized on a Mac, I am currently unable to connect to the internet to do the continue in the instillation, the network has 'no available connections' I have ran into similar issues with this before when attempting to install Linux based operating systems. I tried looking at other topics and could not find a fix. Help would be greatly appreciated.
Let me know if any data is needed, the output of [garuda-inxi] is below.
Kernel: 5.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
misobasedir=garuda misolabel=GARUDA_DR460NIZED_TALON quiet
systemd.show_status=1 driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
Type: Desktop System: Apple product: iMac14,1 v: 1.0
serial: <superuser required> Chassis: type: 13 v: Mac-031B6874CF7F642A
Mobo: Apple model: Mac-031B6874CF7F642A v: iMac14,1
serial: <superuser required> UEFI: Apple v: 433.120.6.0.0 date: 03/16/2022
Info: model: Intel Core i5-4570R bits: 64 type: MCP arch: Haswell
gen: core 4 built: 2013-15 process: Intel 22nm family: 6
model-id: 0x46 (70) stepping: 1 microcode: 0x1C
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2694 high: 2695 min/max: 800/3200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2694 2: 2694 3: 2694
4: 2695 bogomips: 21551
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel vendor: Apple driver: i915 v: kernel ports: active: DP-3
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0d22 class-ID: 0300
Device-2: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
bus-ID: 1-7:5 chip-ID: 05ac:8511 class-ID: 0e02 serial: <filter>
Monitor-1: DP-3 model: Apple iMac built: 2012 res: 1920x1080 hz: 60
dpi: 103 gamma: 1.2 size: 475x267mm (18.7x10.51") diag: 545mm (21.5")
ratio: 16:9 modes: max: 1920x1080 min: 960x540
OpenGL: renderer: Mesa Intel Iris Pro Graphics 5200 (HSW GT3)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: Intel Crystal Well HD Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0d0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
chip-ID: 14e4:1686 class-ID: 0200
IF: enp3s0f0 state: down mac: <filter>
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb
v: 0.8 bus-ID: 1-8.3:9 chip-ID: 05ac:828d class-ID: fe01
Local Storage: total: 1.37 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: HDD HTS541010A9E662
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: B5D0
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: Flash Disk
size: 3.83 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.00 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Hitachi model: G ST
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 0000 scheme: MBR
ID-1: swap-1 type: zram size: 7.7 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 66.0 C mobo: N/A
Processes: 181 Uptime: 12m wakeups: 0 Memory: 7.7 GiB
used: 1.87 GiB (24.2%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1181 lib: 302
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.17
Garuda (2.6.3-2):
System install date: 2022-07-02
Last full system update: 2022-07-02 ↻
