Hi everyone.
Seems there are similar issues with Gnome. But latest Manjaro works fine.
After installing on my laptop everything works as expected but the installer does an upgrade which results in a frozen desktop. With a bit of luck I can open the terminal which then works. Hitting the super key also works a bit . . . .
I have the same problem with CachyOS so its probably an ARCH problem.
Any ideas / or should I wait for a while ?
misobasedir=garuda root=miso:LABEL=GARUDA_GNOME_RAPTOR quiet
systemd.show_status=1 ibt=off driver=free nouveau.modeset=1
Desktop: GNOME v: 45.0 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: Latitude E6510 v: 0001
Mobo: Dell model: 02K3Y4 v: A02 serial: <superuser required> BIOS: Dell
v: A17 date: 05/12/2017
ID-1: BAT0 charge: 23.7 Wh (58.8%) condition: 40.3/48.8 Wh (82.5%)
volts: 11.2 min: 11.1 model: Samsung SDI DELL PT43699 type: Li-ion
Info: model: Intel Core i5 M 580 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2658 high: 3316 min/max: 1199/2667 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3316 2: 3060
3: 1199 4: 3059 bogomips: 21281
Device-1: Intel Core Processor Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: Ricoh HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.4:3 chip-ID: 05ca:1814
class-ID: 0e02
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x029e built: 2009 res: 1600x900
dpi: 118 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1600x900
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
16.0.6 128 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Dell Latitude E6510 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-1: Intel 82577LM Gigabit Network vendor: Dell Latitude E6510
driver: e1000e v: kernel port: 7040 bus-ID: 00:19.0 chip-ID: 8086:10ea
Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:422c
Device-1: Dell DW375 Bluetooth Module driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.7:4
chip-ID: 413c:8187 class-ID: fe01 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 4 state: up address: <filter> bt-v: 3.0
lmp-v: 5 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 140.43 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Corsair model: Force 3 SSD
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Ultra size: 28.64 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00 scheme: GPT
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 66.0 C mobo: N/A sodimm: SODIMM C
Fan Speeds (rpm): cpu: 0
Processes: 209 Uptime: 46m wakeups: 2 Memory: total: 8 GiB
available: 7.68 GiB used: 2.03 GiB (26.5%) Init: systemd v: 254
pm: pacman pkgs: 1165 libs: 365 tools: paru Shell: fish v: 3.6.1
running-in: gnome-terminal inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-12-29
Last full system update: 2023-12-29 ↻
Failed units: snapper-clean
