root=UUID=d99907ec-3ab2-494b-b1b7-1f23eba254b6 rw rootflags=subvol=@
quiet
cryptdevice=UUID=c268dbb9-451f-444d-b736-3ac457f59235:luks-c268dbb9-451f-444d-b736-3ac457f59235
root=/dev/mapper/luks-c268dbb9-451f-444d-b736-3ac457f59235 quiet
rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 amd_iommu=on
amd_iommu=pt ibt=off
Mobo: ASUSTeK model: ROG STRIX B550-I GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2803
date: 04/28/2022
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3553 high: 3593 min/max: 2200/4467 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3593 2: 3591
3: 3593 4: 3593 5: 3500 6: 3591 7: 3500 8: 3500 9: 3592 10: 3592 11: 3500
12: 3500 bogomips: 83845
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: eVga.com.
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.0 chip-ID: 10de:2208
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-2 pos: primary res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: None-1-1 size-res: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.269 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3080 Ti driver: nvidia v: 535.113.01 device-ID: 10de:2208
surfaces: xcb,xlib
Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 10de:1aef
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.82 TiB used: 1.63 TiB (89.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 33.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.63 TiB (89.6%)
mapped: luks-c268dbb9-451f-444d-b736-3ac457f59235
used: 1.63 TiB (89.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-1: swap-1 type: zram size: 31.23 GiB used: 33 MiB (0.1%) priority: 100
System Temperatures: cpu: 33.5 C mobo: 34.0 C gpu: nvidia temp: 50 C
Fan Speeds (rpm): fan-1: 0 fan-2: 822 fan-5: 3781 gpu: nvidia fan: 50%
Processes: 324 Uptime: 5h 46m wakeups: 0 Memory: total: 32 GiB
available: 31.23 GiB used: 7.9 GiB (25.3%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 11/12
clang: 16.0.6 Packages: pm: pacman pkgs: 2138 libs: 568 tools: octopi,paru
Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2022-12-31
Last full system update: 2023-11-01
Please help with diagnosing and fixing dependency problem.
When trying to update Garuda, I get following error:
:: installing xdman-beta-bin (8.0.29-6) breaks dependency 'xdman' required by firedragon-extension-xdm-browser-monitor
Iāve found that I can use pacman -Qi to find dependencies of packages.
According to that, firedragon-extension-xdm-browser-monitor requires xdman. The package xdman-beta-bin (thatās getting updated from 8.0.29-5 to 8.0.29-6) says it āprovidesā xdman, so I assume that should satisfy the dependency.
This is where I got lost.
- How does installing package breaks dependency? Does the updated package no longer provide the dependency? (Is there some way to check this?)
- I assume I canāt control what package maintainers put as dependences for the packages. How can I resolve the issue? Iām not sure if I should just uninstall the extension as it was included with the system. Either way, Iād like to know proper way to deal with the situation to be able to deal with similar situations in the future.
- Are there some good practices to study to avoid dependency issues in the future? It happens to me quite a lot that I canāt update system because of dependency issue.
Iām sorry if this is stupid question, Iāve been using Debian-based distros for my whole life till now, the philosophy there is quite different regarding package management.
