Installing wayfire-git (0.8.0 58) brake dependency 'libwlroots.so=11' required by sway garuda os
[sudo] password for psyfucx:
:: Synchronising package databases...
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
error: failed retrieving file 'extra.db' from ca.mirrors.cicku.me HTTP/2 stream 1 was not closed cleanly: INTERNAL_ERROR (err 2) --> Refreshing mirrorlists using rate-mirrors, please be patient..✔
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
error: failed retrieving file 'extra.db' from ca.mirrors.cicku.me HTTP/2 stream 1 was not closed cleanly: INTERNAL_ERROR (err 2) :: Starting full system upgrade...
warning: garuda-settings-manager: local (1.0.2-5) is newer than garuda (1.0.2-3)
resolving dependencies...
:: installing wayfire-git (0.8.0.r58.gb5c0a0b4-1) breaks dependency 'libwlroots.so=11' required by sway Press enter to exit
psyfucx@psyfucx in ~ took 1s
-A sudo garuda-inxi
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: hpet available: acpi_pm
root=UUID=051441d4-413c-495b-b526-07749c96f5e4 rw rootflags=subvol=@ quiet resume=UUID=672e0bbf-5380-4f9e-9990-0ed3292cec94 loglevel=3 ibt=off Desktop: sway v: 1.8.1 info: waybar dm: greetd Distro: Garuda Linux base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Laptop 15-eh1xxx v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 88D0 v: 78.13 serial: <filter> UEFI: AMI v: F.10 date: 07/22/2021
ID-1: BATO charge: 5.1 Wh (18.3%) condition: 27.8/27.8 Wh (100.0%)
volts: 10.7 min: 11.3 model: HP Primary type: Li-ion serial: <filter> status: discharging cycles: 159
Info: model: AMD Ryzen 5 5500U with Radeon Graphics socket: FP6 bits: 64 type: MT MCP arch: Zen 2 gen: 3 Level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 649 high: 1397 min/max: 400/4056 base/boost: 2100/4050
scaling: driver: amd-pstate-epp governor: powersave volts: 1.2 V ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 1397 6: 400
7: 400 8: 400 9: 1397 10: 400 11: 400 12: 1397 bogomips: 50304 Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm Vulnerabilities: <filter>
Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1, HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300 temp: 43.0 C
Device-2: Luxvisions Innotech HP Wide Vision HD Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s Lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 30c9:000e class-ID: 0e02
Display: server: Xwayland v: 23.2.3 compositor: sway v: 1.8.1 driver:
gpu: amdgpu display-ID: 0 note: <missing: xdpyinfo/xrandr> Monitor-1: eDP-1 model: BOE Display 0x095d built: 2020 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL Message: EGL data requires eglinfo. Check --recommends. Audio:
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s Lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api tools: N/A Server-1: sndiod v: N/A status: off tools: aucat,midicat, sndioctl Server-2: PipeWire v: 1.0.0 status: n/a (root, process) with:
1: pipewire-pulse status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin tools: pactl, pw-cat, pw-cli, wpctl
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:c822 class-ID: 0280
IF: wlo1 state: up mac: <filter> Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: Obda:b00c class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1 Imp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 16.01 GiB (3.4%)
model: MTFDHBA512QFD-1AX1AABHA size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1022 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 460.17 GiB size: 460.17 GiB (100.00%)
used: 16.01 GiB (3.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
Used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 460.17 GiB size: 460.17 GiB (100.00%)
ID-4: /var/log raw-size: 460.17 GiB size: 460.17 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.17 GiB size: 460.17 GiB (100.00%)
Kernel: swappiness: 133 (default 60) cache-pressure: 100 (default) zswap: no ID-1: swap-1 type: zram size: 14.97 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle, lz4, lz4hc,842 max-streams: 12 dev: /dev/zramo ID-2: swap-2 type: partition size: 16.47 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 48.4 C mobo: N/A gpu: amdgpu temp: 44.0 C Fan Speeds (rpm): fan-1: 0 fan-2: 0
Processes: 384 Uptime: 29m wakeups: 0 Memory: total: 16 GiB note: est. available: 14.97 GiB used: 3.52 GiB (23.5%) Init: systemd v: 255
pm: pacman pkgs: 1261 libs: 382 tools: pamac, paru Shell: garuda-inxi (sudo) default: Bash v: 5.2.21 running-in: alacritty inxi: 3.3.31
Garuda (2.6.21-1):
System install date:
2023-12-02
Last full system update: 2023-12-20
Is partially upgraded:
Relevant software:
Windows dual boot:
Yes
snapper NetworkManager dracut No/Undetected
Hello, welcome to the forums. Please post your garuda-inxi as requested by the assistance template.
Edited my post. Thanks.
Looking forward for solution
The easy, no-brainer solution here is don’t install wayfire-git.
If you already installed it you can remove it like this:
sudo pacman -R wayfire-git
