Installing Synology Drive
Hi, I’m trying to install Synology Drive, I found only flatpak, and the installations shows error:
Aborted due to failure (Error deploying: While trying to apply extra data: apply_extra script failed, exit status 256)
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f8a4b7fb-d791-4428-b227-164e22925800 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: Z790 AORUS ELITE X WIFI7 v: -CF
Mobo: Gigabyte model: Z790 AORUS ELITE X WIFI7 v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F5g
date: 12/08/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x11D
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 1991 high: 4914 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1599 2: 4914 3: 2537
Please, use
sudo pacman -Syu synology-drive
its prebuild in chaotic-aur for you :slight_smile:
Btw, maybe you can post the full garuda-inxi?
Thanks!
See below. This is my new built PC, I used to run Manjaro (no issues, just wanted to try Garuda…) and KDE Neon before. Garuda works really nice, no issues beside I cant get WiFi and BT to work due to Mediatec chip :frowning: I use it for daily work, office / web development, simple graphics edit. Really nice system.
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
date: 12/08/2023
microcode: 0x11D
Speed (MHz): avg: 882 high: 1329 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 800 3: 1100
4: 800 5: 800 6: 800 7: 800 8: 1329 9: 932 10: 800 11: 1100 12: 800
13: 800 14: 800 15: 1083 16: 800 17: 800 18: 800 19: 940 20: 800 21: 800
22: 800 23: 800 24: 800 bogomips: 164044
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte
driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: none empty: DP-3,HDMI-A-3,HDMI-A-4 bus-ID: 00:02.0
chip-ID: 8086:a780 class-ID: 0380
Device-2: NVIDIA GA104 [GeForce RTX 3060] vendor: Gigabyte driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 01:00.0 chip-ID: 10de:2487 class-ID: 0300
alternate: fbdev,intel,nv,vesa dri: iris gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.70x13.43")
s-diag: 692mm (27.24")
Monitor-1: DP-2 note: disabled model: ASUS PA279 serial: <filter>
built: 2023 res: 3840x2160 hz: 60 dpi: 163 gamma: 1.2
max: 3840x2160 min: 640x480
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
memory: 11.72 GiB
API: Vulkan v: 1.3.276 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 545.29.06
device-ID: 10de:2487 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 23.3.5-arch1.1
device-ID: 8086:a780 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
Device-2: NVIDIA GA104 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
Device-1: MEDIATEK vendor: Foxconn driver: N/A pcie: gen: 3 speed: 8 GT/s
lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 14c3:7927 class-ID: 0280
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-14:7
chip-ID: 0489:e10f class-ID: e001 serial: <filter>
Local Storage: total: 4.34 TiB used: 178.66 GiB (4.0%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 35.9 C
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Samsung
model: MZVL2512HCJQ-00BL7 size: 476.94 GiB block-size: physical: 512 B
fw-rev: CL2QGXA7 temp: 42.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:9 vendor: Samsung
model: MZVLB256HAHQ-000L7 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 1L2QEXD7 temp: 33.9 C scheme: GPT
ID-4: /dev/nvme3n1 maj-min: 259:3 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 38.9 C
used: 178.63 GiB (37.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:8
used: 27.2 MiB (9.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:7
ID-1: swap-1 type: zram size: 62.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.0 C mobo: 27.0 C gpu: nvidia temp: 48 C
Processes: 515 Uptime: 3h 39m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.56 GiB used: 9.41 GiB (15.0%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1510
pm: pacman pkgs: 1501 libs: 424 tools: octopi,pamac,paru pm: flatpak pkgs: 9
Shell: fish v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.23-1):
System install date:     2023-12-24
Last full system update: 2024-02-08 ↻
Just reboot, it fix sometimes, “errors” in KDE.
Synology works?
Yes, yes, works fine. Beside that “On Demand Sync” is not available on Linux… it’s a pitty. I appreciate your help.
