Installing octopy in Garuda-Cinnamon
Please, any guide to install Octopy on Garuda-Cinnamon? I can’t install it.
    root=UUID=e38ee0d4-0c6f-4526-9adf-c7cf1a1f23b5 rw rootflags=subvol=@
  Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM
    v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 20217 v: Lenovo IdeaPad Y510P
    serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad Y510P
  Mobo: LENOVO model: VIQY0Y1 v: 31900004WIN8 STD SGL
    serial: <superuser required> UEFI: LENOVO v: 74CN44WW(V3.05)
    date: 09/18/2013
  ID-1: BAT1 charge: 42.5 Wh (100.0%) condition: 42.5/56.4 Wh (75.3%)
    power: 655.4 W volts: 12.2 min: 10.8 model: LENOVO PABAS0241231 type: Li-ion
    serial: <filter> status: full
  Info: model: Intel Core i7-4700MQ bits: 64 type: MT MCP arch: Haswell
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 2622 high: 3378 min/max: 800/3400 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 3378 2: 3118 3: 3276
    4: 800 5: 3194 6: 800 7: 3251 8: 3161 bogomips: 38313
  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
    driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
    active: VGA-1,eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0416
  Device-2: NVIDIA GK107M [GeForce GT 750M] vendor: Lenovo driver: nouveau
    v: kernel non-free: series: 470.xx+ status: legacy-active (EOL~2023/24)
    arch: Kepler code: GKxxx process: TSMC 28nm built: 2012-18 pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:0fe4 class-ID: 0300 temp: 46.0 C
  Device-3: Realtek [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0bda:58b9 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.9 driver: X: loaded: modesetting
    alternate: fbdev,intel,nouveau,nv,vesa dri: crocus,nouveau gpu: i915
  Screen-1: 0 s-res: 2966x900 s-dpi: 96 s-size: 784x238mm (30.87x9.37")
    s-diag: 819mm (32.26")
  Monitor-1: VGA-1 pos: right model: LG (GoldStar) 20EN33 serial: <filter>
    built: 2013 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
    size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes:
    max: 1600x900 min: 720x400
  Monitor-2: eDP-1 pos: primary,left model: LG Display 0x033a built: 2011
    res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
    vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  Device-2: Intel 8 Series/C220 Series High Definition Audio
    vendor: Lenovo 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:8c20 class-ID: 0403
  Device-3: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
  Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Lenovo
    driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 07:00.0 chip-ID: 1969:10a1 class-ID: 0200
  Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:08b1 class-ID: 0280
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:5 chip-ID: 8087:07dc
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.0
    lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 2.27 TiB used: 4.8 GiB (0.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
  ID-1: / raw-size: 100.42 GiB size: 100.42 GiB (100.00%) used: 4.7 GiB (4.7%)
    fs: btrfs dev: /dev/sdb4 maj-min: 8:20
  ID-2: /boot/efi raw-size: 1.86 GiB size: 1.86 GiB (99.80%)
    used: 576 KiB (0.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw-size: 309.96 GiB size: 309.96 GiB (100.00%)
    used: 94 MiB (0.0%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
  ID-4: /var/log raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
    used: 4.7 GiB (4.7%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
  ID-5: /var/tmp raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
  ID-2: swap-2 type: partition size: 20.12 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 89.0 C mobo: N/A gpu: nouveau temp: 46.0 C
  Processes: 272 Uptime: 12m wakeups: 1 Memory: total: 16 GiB
  available: 15.53 GiB used: 2.47 GiB (15.9%) Init: systemd v: 254
  pm: pacman pkgs: 1173 libs: 353 tools: paru Shell: fish v: 3.6.1
  running-in: gnome-terminal inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2024-02-04
  Last full system update: 2023-10-29
Why not? What kind of error messages are you receiving?
It’s not enough to say, “this doesn’t work.”
That is of no value whatsoever.
Done, installed with pacman.
Thanks.
I think something like “not found/exist”
There is no octopy, seems the user want octopi, but who knows. :man_shrugging:
So I have to remove the solution.
