Kernel: 6.9.5-1-cachyos arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: root=UUID=8a69f047-feee-46cf-81a1-d299eb173883 rw
rootflags=subvol=@ loglevel=3 sysrq_always_enabled=1 amd_pstate=active
amdgpu.ppfeaturemask=0xffffffff tsc=reliable clocksource=tsc nowatchdog
nmi_watchdog=0 initrd=\@\boot\initramfs-linux-cachyos.img
Desktop: KDE Plasma v: 6.1.0 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: P5.10
date: 10/20/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3477 high: 4575 min/max: 550/4651 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4575 2: 3659 3: 3659
4: 3659 5: 3660 6: 3654 7: 3677 8: 550 9: 3660 10: 3657 11: 3658 12: 3658
bogomips: 88809
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-2,HDMI-A-2 empty: HDMI-A-1,Writeback-1
bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
compositors: 1: Gamescope 2: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 4980x2513 display-ID: 0
Monitor-1: DP-1 pos: bottom-r res: 2048x864 size: N/A modes: N/A
Monitor-2: DP-2 pos: primary,top-left res: 1396x785 size: N/A modes: N/A
Monitor-3: HDMI-A-2 pos: middle-c res: 1536x864 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
navi22 LLVM 17.0.6 DRM 3.57 6.9.5-1-cachyos) device-ID: 1002:73df
memory: 11.72 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.279 layers: 22 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28
Device-2: Sony INZONE H9 / H7
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 054c:0e53
class-ID: 0a00
API: ALSA v: k6.9.5-1-cachyos status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Edimax Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: 7392:c611
lmp-v: 10 status: discoverable: yes pairing: yes class-ID: 6c0104
Local Storage: total: 5.46 TiB used: 5.48 TiB (100.5%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731120WD temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 35.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN006-3CW104
tech: HDD rpm: 5400 serial: <filter> fw-rev: SC60 scheme: GPT
used: 860.63 GiB (92.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 42.1 MiB (14.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.26 GiB used: 3.16 GiB (10.1%)
System Temperatures: cpu: 59.2 C mobo: 35.0 C gpu: amdgpu temp: 54.0 C
mem: 56.0 C
Fan Speeds (rpm): cpu: 2280 fan-1: 0 fan-3: 1312 fan-4: 1393 fan-5: 1270
gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.28 vbat: 3.28 gpu: amdgpu watts: 28.00
Memory: total: 32 GiB available: 31.26 GiB used: 15.48 GiB (49.5%)
Processes: 602 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
image: 12.48 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: 2890 pm: pacman pkgs: 2840 libs: 621 tools: octopi,paru,yay
pm: appimage pkgs: 0 pm: flatpak pkgs: 50 Compilers: clang: 17.0.6
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: alacritty inxi: 3.3.34
System install date: 2024-01-11
Last full system update: 2024-06-20
as the title says, I cannot update because of a dependency issue with game scope.
update
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
warning: itch-setup-bin: local (1.26.0-1.2) is newer than chaotic-aur (1.26.0-1)
warning: organize: ignoring package upgrade (2.2.0-1 => 3.2.3-1)
resolving dependencies...
:: installing libdisplay-info (0.2.0-1) breaks dependency 'libdisplay-info.so=1-64' required by gamescope
