╭─shlomy79@shlomi in ~
╰─λ garuda-inxi
Kernel: 6.9.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=acb03c0d-fae3-4baa-8c07-0871c0971e77 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: F50
date: 11/27/2019
Info: model: AMD Ryzen 5 2400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 3001 high: 3600 min/max: 1600/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2736 2: 2974
3: 2969 4: 2917 5: 3600 6: 2970 7: 2966 8: 2877 bogomips: 57492
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DVI-D-1 bus-ID: 07:00.0 chip-ID: 1002:15dd
class-ID: 0300 temp: 38.0 C
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.7-arch1.3
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 11 Graphics
(radeonsi raven LLVM 17.0.6 DRM 3.57 6.9.1-zen1-1-zen)
device-ID: 1002:15dd memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Vega 11 Graphics (RADV RAVEN) driver: mesa radv v: 24.0.7-arch1.3
device-ID: 1002:15dd surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.7-arch1.3 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Focusrite-Novation Scarlett 2i2 3rd Gen
driver: snd-usb-audio,usb-storage type: USB rev: 2.1 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 1235:8210 class-ID: 0806
API: ALSA v: k6.9.1-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 506.01 GiB used: 66.44 GiB (13.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: XPG GAMMIX S11
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SVN139B temp: 31.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Transcend model: JetFlash 64GB
size: 58.88 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1100 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 model: Scarlett Welcome Disk size: 192 KiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 0.10 scheme: MBR
ID-1: / raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
used: 66.44 GiB (14.9%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
ID-3: /var/log raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
ID-4: /var/tmp raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.6 GiB used: 2.38 GiB (17.5%)
System Temperatures: cpu: 48.0 C mobo: 35.0 C gpu: amdgpu temp: 48.0 C
Memory: total: 16 GiB note: est. available: 13.6 GiB used: 9.53 GiB (70.1%)
Processes: 280 Power: uptime: 9h 51m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.43 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1502 libs: 427 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-01-26
Last full system update: 2024-05-19 ↻
~~~╭─shlomy79@shlomi in ~ took 2s
╰─λ update -- --overwrite '*'
[sudo] password for shlomy79:
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur 774.6 KiB 705 KiB/s 00:01 [--------------------------------------------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su --overwrite *
resolving dependencies...
:: installing icu (75.1-1) breaks dependency 'libicuuc.so=74-64' required by gspell
:: installing icu (75.1-1) breaks dependency 'libicuuc.so=74-64' required by harfbuzz-icu
:: installing icu (75.1-1) breaks dependency 'libicuuc.so=74-64' required by raptor
:: installing icu (75.1-1) breaks dependency 'libicui18n.so=74-64' required by thunderbird
:: installing icu (75.1-1) breaks dependency 'libicuuc.so=74-64' required by thunderbird
shlomy79:
icu
No problems here with icu 75.1-1.
Seams you need to wait for upstream fix by gspell, harfbuzz-icu and so on.
will wait some days and try again
I had a similar issue today with that exact package (icu dependency conflicts with those similar packages) and I solved it with:
$> garuda-update remote fix
$> garuda-update -a
Similar resolved issue on EndeavourOS forums:
I’ve been using endeavour for a couple of years now with virtually no issues. However, I went to update my system today by running yay and there is a core package icu that runs into an issue: :: Starting full system upgrade... resolving...
Reading time: 3 mins 🕑
Likes: 3 ❤
Conclusion:
Just re-rate your mirrors using reflector-simple and run sudo pacman -Syyu
I am always in favor of simple solutions.
Just waited a bit and most icu related issues were resolved. (Had to remove electron22 and revolt-desktop-git as Revolt hasn’t seen updates in quite some time anyways)
Why upgrade EOS with an AUR helper?
The Arch Linux package manager is called pacman.
Tony Stark is a billionaire,playboy and philantropist without his suit. He doesn’t need his suit but his suit does add more to him. Similarly, pacman is awesome without yay but yay sure does add more to pacman.
i tried all solutions but still have the same problem
résolution des dépendances…
recherche des conflits entre paquets…
erreur : la préparation de la transaction a échoué (la satisfaction des dépendances a échoué)
:: l’installation de icu (75.1-1) casse la dépendance « libicuuc.so=74-64 » requise par qt5-webkit
:: l’installation de icu (75.1-1) casse la dépendance « libicui18n.so=74-64 » requise par qt5-webkit
i agree but i’ve to wait then ?
Try qt5-webkit-git instead ?
LolFlasherNoobX:
qt5-webkit-git
for me it’s an icu issue, not qt5-webkit…i had the pb before but i can’t solve it this time
nepti
21 May 2024 18:01
16
Nope, it’s a problem of qt5-webkit. Just wait for a fix…
opened 07:30PM - 19 May 24 UTC
closed 04:23AM - 22 May 24 UTC
waiting:upstream-fix
request:rebuild-pkg
### Packages:
https://aur.archlinux.org/packages/qt5-webkit
### Latest chaotic… version
latest
### Reason for rebuild
After the update of `icu` package to 75, `qt5-webkit` seems to break by the following error:
warning: cannot resolve "libicuuc.so=74-64", a dependency of "qt5-webkit"
warning: cannot resolve "libicui18n.so=74-64", a dependency of "qt5-webkit"
:: The following package cannot be upgraded due to unresolvable dependencies:
qt5-webkit
:: Do you want to skip the above package for this upgrade? [y/N]
### Logs
_No response_
### Builds?
_No response_
### More information
_No response_
Qt5-webkit got dropped from Chaotic-AUR because of build issues and being deprecated since a long time. It’s likely best to search for alternatives of apps depending on it.
i agree but i have quite a long list
I am patiently waiting for the fix for this. I am getting the following error:
:: installing icu (75.1-1) breaks dependency ‘libicui18n.so=74-64’ required by electron25
:: installing icu (75.1-1) breaks dependency ‘libicuuc.so=74-64’ required by electron25
I have tried all of the fixes listed in this thread but so far none have worked
