While installing Garuda this error pop while installing
Sunday, Oct 13 |
3:29 PM
Garuda Linux Installer
Error
Installation failed
There was an error installing the bootloader
Details:
Failed to install bootloader; the installation command <pre>grub-install-target-x86_64-efi--efi-directory=/boot/efi--bootloader-id=Garuda-force</pre> returned error code 1.
I know the bootloader on the daily ISO image has not been working for a long time. You have to boot and install the Garuda from 04-28-2024 ISO image, and update the system after install. I had to do that on my laptop.
A common reason for getting this error message is attempting to use an EFI partition which does not have enough free space to complete the installation. Are you installing alongside an existing Windows installation?
We won’t know for sure what is happening until we see the installation log. After the installer exits, run this command and put the URL it outputs into the thread so we can take a look:
Yes, for me as well. If someone is having an issue using the 240428 ISO with Ventoy, probably they need to update Ventoy itself (https://www.ventoy.net/en/doc_start.html). The newer ISOs (from the builds URL) do not work with Ventoy.
