Hello, garudanians.
Let me tell that Its different approach with other issue in forum.
My issue is the installation of Garuda Linux dragonized being installed as Vanilla KDE without any dot files at /home/$USER.
I’am moving to use garuda after having system corrupt, my installation using separated ext4 /home partition from previous distro, and pre-formated btrfs / root partition.
I cant use “using previous home partition” in calamares because my laptops are GPT drives which runs on Legacy Bios. So, i have to use manual partition to avoid error. These are the procces of my interactions to fix the issue :
mv .* to backup_folder # in my $HOME for emergency in case of dot files overwrited
- Then after it, i’am installing garudalinux on root partition and reuse /home partition with the same $USER as old distro.
- System boot properly but, its vanilla.
- Copying dot files from live-boot usb could FIX IT
- But dolphin file explorer is using /home/garuda instead using /home/$USER
- Default location in system settings was set to /home/$USER but no effects.
- Could anyone tell other issue if iam using dot files from live-boot usb and fix the current failure in dot files?
Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=6888a136-1fd4-461d-a010-b0224472ac66 rw rootflags=subvol=@
loglevel=3 intel_iommu=off ibt=off
Type: Portable System: Dell product: Inspiron N4050 v: N/A
serial: <superuser required> Chassis: type: 8 serial: <superuser required>
Mobo: Dell model: 0J6GG1 v: A08 serial: <superuser required> BIOS: Dell
v: A08 date: 08/03/2012
ID-1: BAT0 charge: 8.9 Wh (100.0%) condition: 8.9/48.8 Wh (18.3%)
volts: 12.5 min: 11.1 model: SMP DELL 8NH5525 type: Li-ion serial: <filter>
status: full
Info: model: Intel Celeron B815 bits: 64 type: MCP arch: Sandy Bridge
level: v2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 1596 min/max: 800/1600 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1596 2: 1596 bogomips: 6385
vendor: Dell driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0106
Device-2: Microdia Laptop_Integrated_Webcam_1.3M driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5:4
chip-ID: 0c45:643e class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: LG Display 0x02e9 built: 2010 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 3.3 Mesa 23.1.3 renderer: Mesa Intel HD Graphics 2000 (SNB
GT1) direct-render: Yes
vendor: Dell 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Dell
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 09:00.0 chip-ID: 168c:002b class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-1: USB2.0-BT driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1.2:3 chip-ID: 33fa:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 536.57 GiB used: 79.54 GiB (14.8%)
ID-1: /dev/sda maj-min: 8:0 model: VENTUZ SATA SSD 256GB size: 238.47 GiB
serial: <filter> fw-rev: 9B0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST320LT020-9YG142
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: DEM1 scheme: GPT
ID-1: / raw-size: 52.43 GiB size: 52.43 GiB (100.00%)
used: 11.97 GiB (22.8%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /boot raw-size: 4.19 GiB size: 4.19 GiB (100.00%)
used: 154.5 MiB (3.6%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 104.86 GiB size: 102.65 GiB (97.90%)
used: 67.43 GiB (65.7%) fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-4: /var/log raw-size: 52.43 GiB size: 52.43 GiB (100.00%)
ID-5: /var/tmp raw-size: 52.43 GiB size: 52.43 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 256 KiB (0.0%) priority: 100
System Temperatures: cpu: 72.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3959
Processes: 214 Uptime: 1h 12m wakeups: 1 Memory: available: 7.67 GiB
used: 3.83 GiB (50.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1285
libs: 341 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date: 2023-06-26
Last full system update: 2023-07-02 ↻
