My problem is confusing. I am aware there is the possibility of installing programs through blackarch. I am in college for cybersecurity so I do intend to learn the ins and outs of web application security. I am however running into an issue with installing even a single application at time. The most common error I run into is with installing a program like zaproxy. Pacman flags it as an invalid or corrupted package. I am aware there are similar issues to which I have attempted a few fixes. Some of which involved signing the gpg keys with pacman-key. Firstly, my issues output is as described in the preformatted text. I included my inxi. Any help would be greatly appreciated as I really enjoy using garuda linux. I have such a wonderful experience using the OS to do many things:
Enter a number (default=1):
Package (5) New Version Net Change Download Size
extra/java-environment-common 3-5 0.00 MiB 0.00 MiB
extra/java-runtime-common 3-5 0.01 MiB 0.00 MiB
extra/jdk-openjdk 23.0.1.u0-1 486.09 MiB 321.26 MiB
extra/libnet 2:1.3-1 1.47 MiB 0.29 MiB
blackarch/zaproxy 2.15.0-1 253.83 MiB 198.18 MiB
Total Download Size: 519.73 MiB
Total Installed Size: 741.40 MiB
:: Retrieving packages...
java-runtime-comm... 5.0 KiB 67.9 KiB/s 00:00 [--------------------------] 100%
java-environment-... 2.6 KiB 34.2 KiB/s 00:00 [--------------------------] 100%
libnet-2:1.3-1-x86_64 295.0 KiB 817 KiB/s 00:00 [--------------------------] 100%
jdk-openjdk-23.0.... 321.3 MiB 3.09 MiB/s 01:44 [--------------------------] 100%
zaproxy-2.15.0-1-any 198.2 MiB 651 KiB/s 05:12 [--------------------------] 100%
Total (5/5) 519.7 MiB 1706 KiB/s 05:12 [--------------------------] 100%
(5/5) checking keys in keyring [--------------------------] 100%
(5/5) checking package integrity [--------------------------] 100%
(5/5) loading package files [--------------------------] 100%
:: File /var/cache/pacman/pkg/zaproxy-2.15.0-1-any.pkg.tar.zst is corrupted (invalid or corrupted package).
Do you want to delete it? [Y/n]
My inxi is
Kernel: 6.11.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4889e54b-9809-4d61-9637-d21da3f36cb2 rw rootflags=subvol=@
quiet resume=UUID=368976cd-6193-4ad4-99b3-bbf926cf7d46 loglevel=3 ibt=off
Desktop: Hyprland v: 0.44.1 with: waybar tools: avail: swayidle,swaylock
vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop System: Micro-Star product: H310 Gaming Trident3 (MS-B920)
v: 2.0 serial: <superuser required>
Mobo: Micro-Star model: MS-B9201 v: 2.0 serial: <superuser required>
part-nu: B920.9 uuid: <superuser required> UEFI: American Megatrends v: 9.30
date: 04/30/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF8
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
bogomips: 34798
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Micro-Star MSI
driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:1f82
compositor: Hyprland v: 0.44.1 driver: X: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 1
Monitor-1: DP-1 pos: right model: 100027813 serial: <filter> built: 2021
res: 1920x1080 hz: 60 dpi: 81 gamma: 1.2 scale: 1
size: 609x348mm (23.98x13.7") diag: 690mm (27.2") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 pos: primary,left model: Acer ED320QR S
serial: <filter> built: 2022 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2
scale: 1 size: 609x348mm (23.98x13.7") diag: 801mm (31.5") ratio: 16:9
API: Vulkan v: 1.3.295 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 565.57.01
device-ID: 10de:1f82 surfaces: xcb,xlib,wayland
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
API: ALSA v: k6.11.6-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0aa7
Local Storage: total: 931.51 GiB used: 50.94 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
tech: HDD rpm: 7200 serial: <filter> fw-rev: SDM1 scheme: GPT
ID-1: / raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
used: 50.94 GiB (5.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
ID-4: /var/log raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
ID-2: swap-2 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 38.0 C mobo: N/A
Memory: total: 32 GiB available: 31.27 GiB used: 2.06 GiB (6.6%)
Processes: 218 Power: uptime: 30m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: upowerd Init: systemd
v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1338 libs: 386 tools: pacseek,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: foot
inxi: 3.3.36
System install date: 2024-11-07
Last full system update: 2024-11-08
