Installing ALVR 20.4.3-2 installs alvr-19.1.0.r0.g969899c7-1
Trying to install the most recent version of ALVR 20.4.3-2 as it says in ALVR’s github and octopi with yay instead installs alvr-19.1.0.r0.g969899c7-1
Kernel: 6.5.7-1-clear arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-clear
root=UUID=f343e266-2bba-4823-826a-311cb6319709 rw rootflags=subvol=@
resume=UUID=29f15791-f1dd-436f-902e-804af7e61bb0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: Gigabyte model: B650M AORUS ELITE
serial: <superuser required> UEFI: American Megatrends LLC. v: F8c
date: 08/16/2023
Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4606 high: 5440 min/max: 400/5453 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 5434 2: 5440 3: 4193
4: 5294 5: 4350 6: 5440 7: 5440 8: 400 9: 4351 10: 5153 11: 4350 12: 5434
bogomips: 112592
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2,HDMI-A-1 off: DP-3 empty: DP-1
bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
DP-6, HDMI-A-2 bus-ID: 12:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 37.0 C
s-diag: 1052mm (41.43")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,right
model: ViewSonic XG2401 SERIES serial: <filter> built: 2016 res: 1920x1080
dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77") diag: 609mm (24")
Monitor-2: DP-3 mapped: DisplayPort-2 note: disabled model: Samsung
built: 2010 res: 1920x1080 dpi: 55 gamma: 1.2 size: 160x90mm (6.3x3.54")
diag: 1021mm (40.2") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: left model: Philips PHL 243V5
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (navi22 LLVM
16.0.6 DRM 3.54 6.5.7-1-clear) device-ID: 1002:73df memory: 11.72 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 16 device: 0 type: discrete-gpu name: AMD
Radeon RX 6750 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:164e surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.7-1-clear status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:4 chip-ID: 0bda:8771
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 18.24 TiB used: 7.95 TiB (43.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 34.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000AS0002-1NA17Z
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5980 serial: <filter> fw-rev: AR15 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST8000AS0002-1NA17Z
tech: HDD rpm: 5980 serial: <filter> fw-rev: RT18 scheme: GPT
ID-1: / raw-size: 1.83 TiB size: 1.83 TiB (100.00%) used: 1.55 TiB (84.6%)
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
used: 1.55 TiB (84.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-1: swap-1 type: zram size: 30.49 GiB used: 1.67 GiB (5.5%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc max-streams: 12
System Temperatures: cpu: 65.9 C mobo: N/A
GPU: device: amdgpu temp: 47.0 C mem: 46.0 C fan: 0 watts: 16.00
device: amdgpu temp: 37.0 C
Processes: 534 Uptime: 1h 1m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.49 GiB used: 10.05 GiB (33.0%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: pm: pacman pkgs: 2316 libs: 571
tools: gnome-software,octopi,pamac,paru,yay Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-07-10
Last full system update: 2023-10-17 ↻
Failed units:            run-media-j-8TB2.mount packagekit.service syncthing.service systemd-vconsole-setup.service dev-disk-by-uuid-29f15791-f1dd-436f-902e-804af7e61bb0.swap
This is the version currently in the Chaotic-AUR repo, so the one you most likely would pick up with pacman or octopi (but they should offer you the available “options”).
Is available in the AUR.
I guess it will be a matter of hours for it to be built in the Chaotic-AUR.
If you don’t mind building it
paru alvr
should work. I don’t know why yay didn’t. Maybe for some reasons you ended up to the Chaotic AUR?
If you don’t see the new version in the Chaotic-AUR let’s say within the next 24hh, you should ask for it here:
Edit: you’ll have to ask for it in the thread above (if working from AUR), because it seems it was excluded appositely:
Thanks i followed your suggestion built it with paru and faced no problems so il bring it up to the chaotic aur.
