Installed RTX 5070 FE. Cannot set my resolution and refresh rate to 3440x1440p @ 120 Hz
Just got a new GPU. Installed it, system lets me boot in but I am at really low resolution and refresh rate. How can I fix this because it’s not a great experience right now.
Trying to switch to open source drivers returns this message: removing nvidia-dkms breaks dependency 'nvidia-dkms' required by garuda-nvidia-config
LANGUAGE = "",
LC_ALL = (unset),
LC_CTYPE = (unset),
LC_NUMERIC = "en_US.UTF-8",
LC_COLLATE = (unset),
LC_TIME = "en_GB.UTF-8",
LC_MESSAGES = (unset),
LC_MONETARY = "en_US.UTF-8",
LC_ADDRESS = "en_US.UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8",
LC_MEASUREMENT = "en_US.UTF-8",
LC_PAPER = "en_US.UTF-8",
LC_TELEPHONE = "en_US.UTF-8",
LC_NAME = "en_US.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.15.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=9613693f-dd5c-41e6-afd3-5bc2c13b93e5 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.2 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Desktop System: Gigabyte product: Z790I AORUS ULTRA v: -CF
Mobo: Gigabyte model: Z790I AORUS ULTRA v: x.x
Megatrends LLC. v: F10b date: 12/04/2024
Info: model: Intel Core i7-14700K bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x12F
Topology: cpus: 1x dies: 1 clusters: 11 cores: 20 threads: 28 mt: 8 tpc: 2
st: 12 smt: enabled cache: L1: 1.8 MiB desc: d-12x32 KiB, 8x48 KiB; i-8x32
KiB, 12x64 KiB L2: 28 MiB desc: 8x2 MiB, 3x4 MiB L3: 33 MiB desc: 1x33 MiB
Speed (MHz): avg: 1502 min/max: 800/5500:5600:4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 1502 2: 1502 3: 1502
4: 1502 5: 1502 6: 1502 7: 1502 8: 1502 9: 1502 10: 1502 11: 1502 12: 1502
13: 1502 14: 1502 15: 1502 16: 1502 17: 1502 18: 1502 19: 1502 20: 1502
21: 1502 22: 1502 23: 1502 24: 1502 25: 1502 26: 1502 27: 1502 28: 1502
bogomips: 191385
Device-1: NVIDIA GB205 [GeForce RTX 5070] driver: nvidia v: 575.64.03
alternate: nouveau,nvidia_drm non-free: N/A status: unknown device ID pcie:
gen: 4 speed: 16 GT/s lanes: 16 link-max: gen: 5 speed: 32 GT/s
bus-ID: 01:00.0 chip-ID: 10de:2f04 class-ID: 0300
alternate: fbdev,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: Unknown-1 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96
size: 508x285mm (20x11.22") diag: 582mm (22.93") modes: 1920x1080
API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
wayland: drv: swrast x11: drv: swrast inactive: gbm
API: OpenGL v: 4.5 vendor: mesa v: 25.1.5-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 20.1.7 256 bits)
device-ID: ffffffff:ffffffff memory: 30.37 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 15 device: 0 type: cpu name: llvmpipe
(LLVM 20.1.7 256 bits) driver: mesa llvmpipe v: 25.1.5-arch1.1 (LLVM
20.1.7) device-ID: 10005:0000 surfaces: N/A
Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 link-max: gen: 5 speed: 32 GT/s bus-ID: 01:00.1
chip-ID: 10de:2f80 class-ID: 0403
Device-3: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a014 class-ID: 0300
API: ALSA v: k6.15.6-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Raptor Lake-S PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:12 chip-ID: 8087:0033
Local Storage: total: 1.82 TiB used: 666.36 GiB (35.8%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 40.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 666.36 GiB (35.8%)
used: 624 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 666.36 GiB (35.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.1 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C mobo: 42.0 C
Memory: total: 32 GiB note: est. available: 31.1 GiB used: 6.67 GiB (21.4%)
Processes: 528 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.36 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2019 libs: 558 tools: octopi,paru Compilers:
clang: 20.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
Garuda (2.7.3-1):
System install date:     2025-03-02
Last full system update: 2025-07-14
It’s also impossible to play games now. I’m getting 1 fps across the board. This has to be a driver issue right?
Of course, you need the option to deinstall sudo pacman -Rdd nvidia…
and for your gpu you need the nvidia-open-beta-dkms to install over paru.
deinstall:
sudo pacman -Rdd garuda-nvidia-config nvidia-dkms nvidia-settings nvidia-utils opencl-nvidia libxnvctrl lib32-nvidia-utils lib32-opencl-nvidia gwe python-py3nvml
no reboot
then: to install with all dependence
paru -S nvidia-open-beta-dkms lib32-nvidia-utils-beta lib32-opencl-nvidia-beta nvidia-settings-beta opencl-nvidia-beta nvidia-utils-beta
reboot → test-- if you have issues —> pls post then your garuda-inxi + pacman -Qs nvidia
You should fix this over the konsole
Make sure en_GB and en_US are enabled (search them in the file and remove the # comment, if present) in:
/etc/locale.gen
And re-generate locales
sudo locale-gen
but before this (my mind) make a bios update
https://www.gigabyte.com/Motherboard/Z790I-AORUS-ULTRA-rev-10/support#dl
Think on right settings after:
  • fastboot + secure boot disabled
  • ahci + uefi mode
  • resize bar enabled
Ah I see. Do you know when the official proprietary drivers will support the 5070?
Can`t see in the future…sorry
But are your issues solved ?
Default only one for each topic :innocent:
Did just updating to the beta drivers solve this for you? I have the 5060 Ti. Installing the beta drivers worked but I also had to edit the GRUB configuration to add the kernel parameter. Had this weird issue where the drivers were active on the login screen but when I logged in, suddenly they stopped work.
I’ve decided not to pursue this workaround and would rather just wait until the card becomes supported on Garuda instead.
BTW, Garuda can do nothing, we can wait like you for an upstream solution.
Like you wrote
supported by Nvidia.
And if, this gpu generation came not in the default nvidia-dkms version, if in the
nvidia-open-dkms and you have nvidia-dkms installed.
Without uninstill over pacman with the option -Rdd it won’t work (my mind)
as info:
offtopic
I request @gampel to be renamed in Mr.Nvidia :wink:
…and don’t worry, your system won’t fall into a “black” hole if you install an nvidia-open-beta-dkms driver instead of the nvidia-dkms driver,
but it is a faulty system if you not installed this driver (my mind)
as info:
the first nvidia winstupid rtx driver for this generation was a beta driver (of course with whql) …lol..but without errors ?.. if i read in the great www…sorry..no.
So I tried this and cannot boot into the OS anymore.
I’m stuck on loading initial ramdisk. For like an hour.
So it bricked my install, sadly. I loaded back into a snapshot before I did all that. I’m not sure if this gpu is really compatible with linux at this time.
LANGUAGE = "",
LC_ALL = (unset),
LC_CTYPE = (unset),
Speed (MHz): avg: 5400 min/max: 800/5500:5600:4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 5400 2: 5400 3: 5400
4: 5400 5: 5400 6: 5400 7: 5400 8: 5400 9: 5400 10: 5400 11: 5400 12: 5400
13: 5400 14: 5400 15: 5400 16: 5400 17: 5400 18: 5400 19: 5400 20: 5400
21: 5400 22: 5400 23: 5400 24: 5400 25: 5400 26: 5400 27: 5400 28: 5400
bogomips: 191385
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 5 speed: 32 GT/s
Monitor-1: Unknown-1 res: mode: 1920x1080 hz: 60 scale: 85% (0.85)
to: 2259x1271 dpi: 96 size: 508x285mm (20x11.22") diag: 582mm (22.93")
modes: 1920x1080
display-ID: :1.0
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 5 speed: 32 GT/s bus-ID: 01:00.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:11 chip-ID: 8087:0033
Local Storage: total: 5.46 TiB used: 719.46 GiB (12.9%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 48.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion Desk
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 0911 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 719.46 GiB (38.6%)
used: 719.46 GiB (38.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 51.0 C mobo: 46.0 C
Memory: total: 32 GiB note: est. available: 31.1 GiB used: 5.43 GiB (17.5%)
Processes: 502 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.39 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2012 libs: 557 tools: octopi,paru Compilers:
Garuda (2.7.3-1):
Last full system update: 2025-07-19
