Hi everyone, I recently bought a nvidia gpu (previous was AMD) and decided to install the drivers for it after installing it.
After running through the steps on the arch wiki, I rebooted my system.
I get a black screen, I am able to run commands in the terminal but it doesn’t appear to be connected to the internet so I cannot run an update or other solutions I found here: Computer doesn’t boot, boots to a black screen, or stops at a message
I’m currently using a liveUSB, where my display is also the incorrect resolution for some reason and I cannot change it.
I could not find a fix on the forums, please help if you can.
Here’s the full output of my garuda-inxi
misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZED_RAPTOR quiet
systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0
Type: Desktop Mobo: Micro-Star model: MAG B660M MORTAR WIFI DDR4 (MS-7D42)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.C0
date: 05/19/2023
Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
microcode: 0x2E
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 1156 high: 4400 min/max: 800/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 798 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 1477 10: 800 11: 800 12: 4400
bogomips: 59904
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti 16GB] vendor: Gigabyte
driver: N/A alternate: nouveau non-free: 535.xx+
status: current (as of 2023-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ pcie: gen: 4 speed: 16 GT/s
lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:2805 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.63x7.99")
s-diag: 338mm (13.3")
Monitor-1: Unknown-1 mapped: None-1 res: 1024x768 hz: 60 size: N/A
modes: 1024x768
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast x11: drv: swrast inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 23.2.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 30.47 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22bd
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 04:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 945.83 GiB used: 0 KiB (0.0%)
model: WD BLACK SN750 SE 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 711250WD temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra USB 3.0
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: swap-1 type: zram size: 31.2 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.0 C mobo: N/A
Processes: 283 Uptime: 4m wakeups: 89 Memory: total: 32 GiB
available: 31.2 GiB used: 2.63 GiB (8.4%) Init: systemd v: 254
pm: pacman pkgs: 1228 libs: 353 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2024-01-04
Last full system update: 2024-01-04 ↻
