$ garuda-inxi
Kernel: 6.12.65-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=3caa4a96-5787-457b-817a-8117f05250c4 rw rootflags=subvol=@
cryptdevice=UUID=ec3ee267-8732-4cc4-8960-c39fbbf5c306:luks-ec3ee267-8732-4cc4-8960-c39fbbf5c306
root=/dev/mapper/luks-ec3ee267-8732-4cc4-8960-c39fbbf5c306
resume=/dev/mapper/luks-22d6ffdc-91a9-4c97-ac75-1f30bca3e10c loglevel=1
quiet
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Desktop System: MSI product: MS-7917 v: 1.0
Mobo: MSI model: Z97 GAMING 5 (MS-7917) v: 1.0
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends v: 1.13 date: 02/16/2016
Device-1: hidpp_battery_0 model: Logitech K350 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
Speed (MHz): avg: 4000 min/max: 800/4000 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 4000 2: 4000 3: 4000 4: 4000 5: 4000 6: 4000
7: 4000 8: 4000 bogomips: 64022
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Micro-Star MSI driver: i915 v: kernel arch: Gen-7.5
process: Intel 22nm built: 2013 ports: active: none
empty: HDMI-A-1,HDMI-A-2,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0412
class-ID: 0380
Device-2: Advanced Micro Devices [AMD/ATI] RV790 [Radeon HD 4890]
vendor: ASUSTeK driver: radeon v: kernel alternate: amdgpu arch: TeraScale
code: R6xx/RV6xx/RV7xx process: TSMC 55-65nm built: 2005-13 pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 1 speed: 2.5 GT/s ports:
active: HDMI-A-3 off: DVI-I-1 empty: DIN-1,VGA-2 bus-ID: 01:00.0
chip-ID: 1002:9460 class-ID: 0300 temp: 62.5 C
Display: x11 server: X.Org v: 21.1.21 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: modesetting,radeon alternate: fbdev,intel,vesa dri: r600,crocus
gpu: radeon display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
s-diag: 584mm (22.99")
Monitor-1: DVI-I-1 mapped: DVI-0 note: disabled model: HP E243i
serial: <filter> built: 2019 res: N/A dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: HDMI-A-3 mapped: HDMI-2 pos: primary model: ViewSonic VX2858Sml
serial: <filter> built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 79 gamma: 1.2 size: 621x341mm (24.45x13.43") diag: 708mm (27.9")
API: Vulkan v: 1.4.335 layers: 10 device: 0 type: integrated-gpu
name: Intel HD Graphics 4600 (HSW GT2) driver: mesa intel v: 25.3.3-arch1.2
device-ID: 8086:0412 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.3-arch1.2 (LLVM
Info: Tools: api: vulkaninfo de: xfce4-display-settings
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-3: Advanced Micro Devices [AMD/ATI] RV770 HDMI Audio [Radeon HD
4850/4870] vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 1 speed: 2.5 GT/s bus-ID: 01:00.1
chip-ID: 1002:aa30 class-ID: 0403
API: ALSA v: k6.12.65-1-lts status: kernel-api tools: N/A
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 1969:e091 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:8 chip-ID: 2550:8761
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: class-ID: 0104
Supported mdraid levels: raid1
Device-1: md124 maj-min: 9:124 type: mdraid level: mirror status: active
Info: report: 2/2 UU blocks: 976759808 chunk-size: N/A
Components: Online:
0: sdb maj-min: 8:16 size: 931.51 GiB
1: sda maj-min: 8:0 size: 931.51 GiB
Device-2: md125 maj-min: 9:125 type: mdraid level: mirror status: active
Components: Online:
0: sdd maj-min: 8:48 size: 931.51 GiB
1: sdc maj-min: 8:32 size: 931.51 GiB
Device-3: md126 maj-min: 9:126 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 5552 chunk-size: N/A
Components: Online: N/A Spare:
0: sdc maj-min: 8:32 size: 931.51 GiB state: S
1: sdd maj-min: 8:48 size: 931.51 GiB state: S
Device-4: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
0: sda maj-min: 8:0 size: 931.51 GiB state: S
1: sdb maj-min: 8:16 size: 931.51 GiB state: S
Local Storage: total: raw: 3.86 TiB usable: -1717154056 used: 114.59 GiB
model: WD10EZEX-75ZF5A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD1002FAEX-00Z3A0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
ID-5: /dev/sde maj-min: 8:64 vendor: Seagate model: ST240HM000-1G5152
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: C675 scheme: GPT
ID-6: /dev/sdf maj-min: 8:80 model: General size: 1.86 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 5.00
ID-1: / raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
used: 114.59 GiB (55.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ec3ee267-8732-4cc4-8960-c39fbbf5c306
used: 984 KiB (0.3%) fs: vfat dev: /dev/sde1 maj-min: 8:65
ID-3: /home raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
ID-4: /var/log raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
ID-5: /var/tmp raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.07 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
mapped: luks-22d6ffdc-91a9-4c97-ac75-1f30bca3e10c
System Temperatures: cpu: 39.0 C mobo: N/A gpu: radeon temp: 62.5 C
Memory: total: 16 GiB note: est. available: 15.07 GiB used: 1.66 GiB (11.0%)
Processes: 318 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.98 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 259 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1783 libs: 450 tools: octopi,paru,yay
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9
running-in: xfce4-terminal inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2023-02-21
Last full system update: 2026-01-13 ↻
Relevant software: snapper NetworkManager dracut(custom) mkinitcpio garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
25/26 checks run in 1.01 seconds ⌛
Powered by garuda-health 🦅
--- HIGH ---
- System is using dracut, but garuda-dracut-support is not installed (fix available)
--- LOW ---
--- INFO ---
Having an issue after I install garuda-dracut-support
It seems to timeout when trying to decrypt on startup leaving me unable to access my system.
This is what I get after entering my decrypt key 3 times. One time before grub, and twice during the prompt you see above. Not sure why it needs it 3 times.
I am a bit of a noob with this and I know just enough to do some damage which is bad ![]()
I have already attempted a couple things and have had to boot off snapshots which is how I am posting this now.
I don’t want to keep messing around without getting some solid advice that I hope you experienced guys can give. Thanks!!
