Hi everyone im trying to dualboot garuda and windows(Already disabled secure boot and fast boot).My windows is on ssd and garuda on a hdd.Installation always get stuck on create partion or 1%.Also installation is done using replace partition.
My Error -
The Installer failed to create partition on disk "ST1000DM010-2EP102"
Create a new partition (41.02 GiB, btrfs) on ‘/dev/sda’
Job: Create new partition on device ‘/dev/sda’
Command: sfdisk --force --append /dev/sda
Command: sfdisk --list --output Device,UUID /dev/sda
Job: Set the label on partition ‘/dev/sda5’ to "root"
Command: sfdisk --part-label /dev/sda 5 root
Job: Create file system ‘btrfs’ on partition ‘/dev/sda5’
Command: mkfs.btrfs --force /dev/sda5
Steps I have taken-
-restart pc and run installer
-Create a btfrs partition and use it to be replaced(sda5).
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=us tz=UTC misobasedir=garuda
root=miso:LABEL=GARUDA_DR460NIZEDGAMING_BIRDOFPR quiet
systemd.show_status=1 checksum=y driver=nonfree nouveau.modeset=0
Type: Desktop System: Dell product: OptiPlex 5060 v: N/A
Mobo: Dell model: 0J8G6F v: A03 serial: <superuser required> part-nu: 085B
uuid: <superuser required> UEFI: Dell v: 1.30.0 date: 03/29/2024
Info: model: Intel Core i5-8500 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF6
desc: 1x9 MiB
Speed (MHz): avg: 1833 high: 3901 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3901 2: 800 3: 800 4: 800
5: 800 6: 3900 bogomips: 36000
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer EK241Y E serial: <filter>
built: 2023 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1
GT2) device-ID: 8086:3e92 memory: 15.06 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:3e92 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api with: aoss
Device-1: Intel Ethernet I219-V vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF-ID-1: enp0s20f0u1i1 state: up speed: 425 Mbps duplex: half
mac: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 3060
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 1.08 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1001 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: SATA3 120GB SSD size: 111.79 GiB
serial: <filter> fw-rev: 227F scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: HP model: USB Flash Drive
size: 57.77 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: PMAP scheme: MBR
ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
System Temperatures: cpu: 37.0 C pch: 36.0 C mobo: N/A
Memory: total: 16 GiB available: 15.42 GiB used: 3.2 GiB (20.8%)
Processes: 210 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1846 libs: 539 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-12-29
Last full system update: 2024-12-29 ↻
