Installation Python mount error
OK, after 8 months and a rebuild, my desktop is running. I tried to install Garuda, using my internal drive as /home. I get a Python error regarding mount on that drive before installation begins, and Calamares aborts. I tried formatting the drive as btrfs, and the same error. It does mount properly using Disks.
Help!
I think a little more info may be needed?
can you provide your
I'm still in the live session.
  Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    misobasedir=garuda root=miso:LABEL=GARUDA_MATE_RAPTOR quiet
    systemd.show_status=1 ibt=off systemd.unified_cgroup_hierarchy=1
    driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: MATE v: 1.26.1 info: mate-panel wm: marco v: 1.26.1 vt: 7
    dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Mobo: ASUSTeK model: ROG STRIX B550-A GAMING v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 2806
    date: 10/27/2022
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2688 high: 3700 min/max: 2200/4650 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
    3: 2200 4: 3700 5: 2200 6: 2879 7: 3700 8: 3700 9: 2200 10: 2200 11: 2200
    12: 2877 bogomips: 88804
    vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 08:00.0
    chip-ID: 1002:73df class-ID: 0300
  Display: x11 server: X.Org v: 21.1.7 compositor: marco v: 1.26.1 driver:
    X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: MSI G27C4 serial: <filter>
    built: 2019 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
    missing.
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:ab28
    bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 46.51 TiB used: 29 TiB (62.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWN180 size: 7.28 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
    rpm: 7200 serial: <filter> rev: GX2M scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWE150 size: 4.55 TiB
    rpm: 7200 serial: <filter> rev: FP2A scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400M8120G
    type: SSD serial: <filter> rev: 61E1 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate
    model: Backup+ Hub BK size: 9.1 TiB block-size: physical: 4096 B
    logical: 512 B type: N/A serial: <filter> rev: D781 scheme: GPT
  ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Seagate
    model: Backup+ Hub BK size: 7.28 TiB block-size: physical: 4096 B
    logical: 512 B type: N/A serial: <filter> rev: D785 scheme: GPT
  ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: Seagate
  ID-7: /dev/sdg maj-min: 8:96 type: USB vendor: Seagate
  ID-8: /dev/sdh maj-min: 8:112 type: USB vendor: Verbatim model: STORE N GO
    size: 7.47 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 1100 scheme: MBR
  ID-1: swap-1 type: zram size: 62.69 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 57.5 C mobo: N/A gpu: amdgpu temp: 45.0 C
    mem: 42.0 C
  Processes: 316 Uptime: 25m wakeups: 0 Memory: 62.69 GiB
  used: 3.29 GiB (5.2%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1225
  libs: 326 tools: octopi,paru Shell: Bash v: 5.1.16 running-in: mate-terminal
  inxi: 3.3.25
Garuda (2.6.15-1):
  System install date:     2023-07-04
  Last full system update: 2023-07-04 ↻
  Is partially upgraded:   Yes
The drive I'm trying to mount is sda above.
I ran smartctl and it passed.
What exactly does it say? Copy/paste it into the thread if you can.
Installation Failed
Boost:Python error in job "mount".
Details:
<div><strong>Command '['btrfs', 'subvolume', 'create', '/tmp/calamares-root-a77k3jc2/@']' returned non-zero exit status 1.</strong></div><div>None</div><div><br/>Traceback:</div><div><pre>File &quot;/usr/lib/calamares/modules/mount/main.py&quot;, line 363, in run
    mount_partition(root_mount_point, partition, partitions, mount_options, mount_options_list)
  File &quot;/usr/lib/calamares/modules/mount/main.py&quot;, line 282, in mount_partition
    subprocess.check_call([&quot;btrfs&quot;, &quot;subvolume&quot;, &quot;create&quot;,
  File &quot;/usr/lib/python3.10/subprocess.py&quot;, line 369, in check_call
    raise CalledProcessError(retcode, cmd)</pre></div>
Hmm, I'm not sure on that one. This might be a long shot, but can you try re-flashing the USB? Go for Ventoy if you can.
This person had a similar error message, and a re-do managed to fix it: Install failed Boost.Python error in job "mount" - Installation - EndeavourOS
Downloaded the .iso, flashed it and it is installing!
What’s this line about?
It was the flash drive that I booted from. I was still in the live session when I posted garuda-inxi.
