There are a million tutorials on how to setup booting from a raid0 out there, but many of them are very old, and the methods i have tried generally result in the installer crashing or displaying an error before failing. I’m asking for guidance on how it should be setup for surviving grub and kernel updates, as well as completing the installation to first boot.
I have 2 500GB nvme drives using efi booting. What combination of partitioning, lvm, btrfs, mdraid, or zfs is expected by the installer?
hardware:
sudo garuda-inxi
[sudo] password for nick:
Kernel: 6.8.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=2d73e66c-d677-4ec4-a7c7-1d11f3992ebc rw rootflags=subvol=@
quiet rd.luks.uuid=7f8d5fb0-0d6f-4e8d-9c39-be86e6e54851 loglevel=3
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK B3302CEA_B5302CEA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: B3302CEA v: 1.0 serial: <filter>
uuid: 0cb5ffaa-6b59-b94a-846b-a5d99c40b9af UEFI: American Megatrends LLC.
v: B3302CEA.311 date: 07/04/2023
ID-1: BAT0 charge: 55.8 Wh (100.0%) condition: 55.8/66.1 Wh (84.5%)
volts: 15.7 min: 15.7 model: ASUSTeK B3302CEA type: Li-ion serial: <filter>
status: full cycles: 143
Info: model: 11th Gen Intel Core i5-1135G7 socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 647 high: 1164 min/max: 400/4200 base/boost: 2400/4200
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 1164 5: 400 6: 1155
7: 400 8: 864 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1, HDMI-A-2, HDMI-A-3, HDMI-A-4, HDMI-A-5 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:4 chip-ID: 13d3:56ea
Display: server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: Samsung 0x4158 built: 2020 res: 1920x1080 hz: 60
dpi: 168 gamma: 1.2 size: 290x170mm (11.42x6.69") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 37.99 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 24.0.6-arch1.2
device-ID: 8086:9a49 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.6-arch1.2 (LLVM
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.8.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15fc class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0026
Local Storage: total: 1.05 TiB used: 14.08 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Micron model: 2210 MTFDHBA512QFD
lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA001 temp: 35.9 C
SMART: yes health: PASSED on: 1y 17d 18h cycles: 122
read-units: 18,663,378 [9.55 TB] written-units: 19,716,163 [10.0 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA007 temp: 41.9 C
SMART: yes health: PASSED on: 1y 68d 2h cycles: 158
read-units: 24,181,894 [12.3 TB] written-units: 24,898,561 [12.7 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: Flash Drive FIT
size: 119.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1100 scheme: GPT
ID-1: / raw-size: 119.21 GiB size: 119.21 GiB (100.00%)
used: 14.08 GiB (11.8%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-7f8d5fb0-0d6f-4e8d-9c39-be86e6e54851
used: 728 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 119.21 GiB size: 119.21 GiB (100.00%)
ID-4: /var/log raw-size: 119.21 GiB size: 119.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 119.21 GiB size: 119.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 38.91 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A
Memory: total: 40 GiB available: 38.91 GiB used: 4.13 GiB (10.6%)
igpu: 32 MiB
Processes: 295 Power: uptime: 26m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 15.55 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1889 libs: 545 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
System install date: 2024-05-05
Last full system update: 2024-05-08
╭─nick@macbook in ~ as 🧙 took 7s
╰─λ
Edit: I also require encryption.
