I want to install Garuda Linux on a USB key because dual booting is not recommended.
I have two questions:
Which USB key is recommended for the read and write speeds? For the size, I’m considering purchasing either a 128GB or 256GB one. My usage will mainly be for coding.
Can GRUB recognize the USB key when it’s plugged into my PC and directly launch from the GRUB menu or set up the system with GRUB?
Currently, I have a dual boot setup with Windows and Ubuntu, which is why I already have GRUB on my system.
You will need to go to BIOS for entering live session
From there you can install Garuda on USB stick
And it neither recommended to use USB,
I think you will always need to go to BIOS to boot into it
I have never did it my ownself so I cant say about it
I have always seen this approach as very difficult in past topics in the forum.
I don’t remember how they ended up, but my opinion is that Garuda is a performance-focused distro, and installing it in a USB seems a bit against that logic.
And the difficulties mentioned above may be greater than the dual boot effort.
Thanks for your reply,
I have a SSD NVMe 4.0 of 1TB but I don’t think it’s possible to share it with a new empty volume and install on it?
For example, 500GB for personal files and 500GB for the OS, could it be possible or not?
If you really wanna go the USB route aka use your USB stick as a computer I would recommend something meant to be used in that manner like puppy linux.
Puppy Linux is an operating system and family of light-weight Linux distributions that focus on ease of use and minimal memory footprint. The entire system can be run from random-access memory (RAM) with current versions generally taking up about 600 MB (64-bit), 300 MB (32-bit), allowing the boot medium to be removed after the operating system has started.
puppy linux will boot as root only. Will operate exclusively in RAM and once you are done and wanna shutdown it will ask where to save the new changed state in. Which can be your USB stick or smth.
Yes I know but I am in school and I need my ubuntu for coding and exam I don’t want make a third boot because inside my pc is a NVMe of 500go, maybe delete ubuntu during holydays to switch with Garuda but I thinks juste delete ubuntu on my os and keep Garuda on my ssd if possible
