Kernel: 6.9.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
root=UUID=4f64013a-7f46-4dc0-a552-be58d9224a85 rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> part-nu: SKU uuid: <superuser required> UEFI: American Megatrends
v: 5003 date: 10/07/2023
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check
built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 2
microcode: 0xA20120E
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3591 high: 4350 min/max: 2200/4549 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3475 2: 3505 3: 3479 4: 3476 5: 3400 6: 3593
7: 3484 8: 3594 9: 3695 10: 3846 11: 3480 12: 3608 13: 4350 14: 3479 15: 3524 16: 3478
bogomips: 108796
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI driver: nvidia v: 555.42.02
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-04) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none off: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 0b:00.0 chip-ID: 10de:2684
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0 compositor: kwin_wayland
driver: X: loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia
display-ID: 0
Monitor-1: DP-1 res: 5120x1440 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.42.02 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2 memory: 23.43 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 4090
driver: nvidia v: 555.42.02 device-ID: 10de:2684 surfaces: xcb,xlib,wayland
Device-1: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:22ba class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: b58e:9e84
Device-4: FiiO BTR7 driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 7-4.1:4 chip-ID: 2972:0047 class-ID: 0300
API: ALSA v: k6.9.2-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2526 class-ID: 0280
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: ke
rnel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-5:3 chip-ID: 8087:0025 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1 lmp-v: 10 status:
Local Storage: total: 15.46 TiB used: 2.64 TiB (17.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital model: WD BLACK SN850X 4000GB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: 624311WD temp: 54.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB size: 3.64 TiB
fw-rev: 4B2QJXD7 temp: 48.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN008-2DR166 size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5980 serial: <filter>
fw-rev: SC60 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
fw-rev: 3B6Q scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD2003FZEX-00SRLA0 size: 1.82 TiB
fw-rev: 1A01 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD20EZRZ-00Z5HB0 size: 1.82 TiB
fw-rev: 0A80 scheme: MBR
ID-1: / raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 1.45 TiB (39.9%) fs: btrfs
dev: /dev/nvme1n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 588 KiB (0.2%) fs: vfat
dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 1.45 TiB (39.9%) fs: btrfs
ID-4: /var/log raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 1.45 TiB (39.9%) fs: btrfs
ID-5: /var/tmp raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 1.45 TiB (39.9%) fs: btrfs
ID-1: swap-1 type: zram size: 31.25 GiB used: 25.8 MiB (0.1%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
System Temperatures: cpu: 58.5 C mobo: N/A
Memory: total: 32 GiB available: 31.25 GiB used: 5.15 GiB (16.5%)
Processes: 425 Power: uptime: 4h 57m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.46 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 255
Packages: 1967 pm: pacman pkgs: 1952 libs: 545 tools: gnome-software, octopi, pacseek, pamac,
paru pm: flatpak pkgs: 15 Compilers: clang: 17.0.6 gcc: 14.1.1 alt: 13 Client: shell wrapper
v: 5.2.26-release inxi: 3.3.34
System install date: 2024-05-10
Last full system update: 2024-05-31 ↻
I’m really new to Linux , can anyone assist me on how to get this installed ; I tried another application named roop unleashed but I am stuck at one portion where I need cuda 11.8 sadly on pacseek that’s the only one I’m missing , Also I have this application link below on windows it was a lot easier to install but now That I fully switched to Linux I want to know if this version is able to install this. also if possible can you explain why you type certain words in the konsole , thank you
