garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur 994.5 KiB 597 KiB/s 00:02 [------------------------------------] 100%
Error: failed to connect to https://www.archlinux.org/mirrors/status/json/, consider increasing fetch-mirrors-timeout
Failed to update mirrorlist
--> Applying keyring updates before starting full system update..
error: target not found: chaotic-keyring
warning: garuda-hotfixes-1.1.2-1 is up to date -- skipping
Press enter to exit
im a complete beginner on all things linux, please help
Patience!
Database rebuild is complete, I'm triggering some routines earlier than they would normally run. Most packages should be completely back by now, and the rest in the following 2 hours from this reply. If 2 hours have elapsed and there are still issues, please comment again. Otherwise, this is now solved!
