Install to USB Issues
Hi, I'm trying to install the XFCE version onto a USB. I keep getting the following error in the last stages, I'm also showing the partitions I manually setup since it initially set up a single partition. I'm using uefi.
I'm sure I'm just missing something, I don't have much experience installing to bootable USBs.
Thanks!
Follow
Fat32 must be 260 MB but why you do no not let calamares work for you?
And welcome in the club :slight_smile:
Thanks.
I did let it do the work the first time but it created a single btrfs partition. When I tried to boot off of it it didn't work.
I'll try with a 260 MB partition next.
We do not support installing on usb
If you want to install Arch on USB / Removable medium
https://wiki.archlinux.org/index.php/Install_Arch_Linux_on_a_removable_medium
And welcome to Garuda Linux Forums.
Oops, sda is a boot stick, I missread I thought it was about creating a boot stick on USB.
This is nothing to do with it being a USB disk.
The error message is telling you that you can’t combine a GPT partition layout with BIOS boot mode without an additional partition for BIOS boot support.
The better options are:
  1. Boot in UEFI mode if you want to use GPT.
  2. Use an MBR partition table if you want to boot in BIOS/legacy mode.
