The Grub-Topic and LTS-Kernel are solved topics, would I assume, btw. already clearified.
Thanks anyway for you appreciate efforts.
Yeah I posted that before reading further replies below. I thought since itās already posted I would just leave it there.
Thatās really great thing, thank you so much.
By the way, no trim-option in the fstab? I sow in Garuda-Videos in youtube there is a Garuda-App for setting trim-option, will do it in the same conf-file or somewhere else?.
The best thing of your /etc/fstab, there is the UEFI-partition formatted in vfat and mounted under /boot/efi.
Would almost say: all āproblemsā almost solved.
Maybe I have luck making all partitions at first, than formatting only UEFI & SWAP and finally let overtake from Calamares to make BTRFS-ROOT, Subvolumes, etc.
Thanks anyway
I think have read a comment about not supporting dual-boot or multi-boot, well, to be clear I donāt want to do it, I just want select it from MB-BIOS (Motherboard UEFI-BIOS), I never ask for support dual- or multi-booting and will also not do it in the future.
The installer have just to remain on his only one assigned drive, even grub-os-prober is not wanted ;-).
Thanks for answering first
Well, the partition is an ext4 (8300) see manual partition for Btrfs in Arch-Wiki, āformattedā later as btrfs, hence you cannot state Garuda has nothing to do with ext4 because the partition is one ext4 and nothing else. Btrfs is a kind of wrapper like ZFS too.
If we want to be precise, we should say that this (as also many other distros) use āBtrfs on Root-partitionā that practically is exact the same as āZFS on Root-partitionā.
The ext4 format option, have I posted just to show everybody that ext4 basically donāt understand 4Kn that actually the standard. This cause the formatting of ext4 with two āFā equal to two time Force-Options.
Also vfat must be āforcedā and must indicate or force sector-dimension and other parameters, but, vfat is not a Linux-topic.
āKpartā & āGpartā donāt understand 4Kn either, so, if I format the UEFI-partition with those tools:
grub nor refind.The only OOTB 4Kn-partition are swap (see swap man-page) even it is also very old and btrfs.
If swap & btrfs support out of the box 4Kn (4Kib) and are natively Linux-partitions you cannot define 4Kn as unsupported Hardware at all.
The problem is also a little bit on Calamares-developer-side that cannot react because the distributors of OS also donāt recognize the problem and even donāt work for solution.
If the user let Calamares use an entire ādiskā, underneath is always a āscriptā that partition and format the disk, is this true? => Ergo the Problem is: The distributors use the wrong (middle-aged) partition- & formatting-tool = āKdisk-partā.
Linux-distributors are neither able to modify vfat nor ext4 or wait that ext5 appear, but just to live with what they/we have, right?
The āquick and dirtā solution is very simple:
gptfdisk-tools to partition, in the TUI (in Calamares) with cgdisk by āmanual partitionā and sgdisk for scripting-partitioning by āuse entire diskā.mkfs for formatting UEFI (EF00), Swap (8200) and Btrfs sitting on top of Ext4 (8300=Root), for ācreatingā ZFS (the future) should be allowed in Calamares just to use mounted partitions but the same must be aware of ZFS & Btrfs too.Note: Detection of block-size, gptfdisk-tools and mkfs are mandatory. By the way, the developer of gdisk is also the developer of refind which is much better than grub.
Stop calling 4Kn=4KiB āUnsupported Hardwareā since the specification for ā512eā are defined in 2012 and the advise and the tools to handle those already old specification are at least a decade old.
Nobody want āDualbootā but just not landing by boot-problems in a CLI and donāt know what to do like with/under grub.
Almost thirty replies in this topic for this āsimpleā question? ![]()
The answer is: yes, your disk will work fine. No special considerations need to be made for your disk. Go ahead and use the installer in the normal way, just like everyone else. You donāt need to make any custom formatting decisions or any other unusual preparations. If you run into problems with the installation process, please open a new topic for that.
This is incorrect. Btrfs and ZFS are completely independent filesystems that have nothing to do with ext4. ext4 is not involved in setting up a Btrfs filesystem in any way.
This is also incorrect. See this explanation from the ArchWiki:
mkfs.f2fs(8), mkfs.fat(8), mkfs.ntfs(8) and mkfs.udf(8) use the backing deviceās logical sector size. I.e. they will use 512 byte sectors for 512e disks and 4096 byte sectors for 4Kn disks.
The clunky formatting command you have written above is not necessaryāit will default to 4096 byte sectors on its own.
This is also incorrect. See the explanation from the ArchWiki page linked above:
mkfs.btrfs(8), mkfs.jfs(8), mkfs.nilfs2(8), mkfs.reiserfs(8) and mkswap(8) default to a 4096 byte sector size.
Even filesystems that do not default to 4096 byte sector size typically support it with no intervention needed. As you pointed out yourself, this is not a new standard anymore.
You have not identified a problem that needs to be addressed by the Calamares developers, Garuda Linux, or by anyone else. It seems like the only āproblemā in this topic is a foundational misunderstanding of the significance of your hard driveās physical sector size.
Your disk is unsupported hardware. Garuda Linux doesnāt write the firmware for your hard drive, or anyone elseās. Garuda Linux supports Garuda Linux, and the fact of the matter is this topic has nothing whatsoever to do with Garuda Linux. It seems to have something to do with your hard drive, so it was placed in an appropriate category.
At your insistence, I have moved the topic to a more appropriate category. When you have a chance, give the installation a try and open a new topic if you run into any problems.
